		Omega Help Area => Omega General Help => Topic started by: andycuk71 on 07 May 2007, 11:52:45
				Hi am in Reading Berkshire looking for some help to replace oil cooler on a 3.0l V6 saloon any takers???
 I do have a fridge full of beers!!!!!
				theres a few done your way that may be tempted...
 However - do it yourself - its really not that bad a job and you have a fair bit of beer to yourself...
 Obviously we can help on here when you go through it !  ;)
				There are a few members your way who may be able to help, or as Markie says, have a go yourself.  Easy enough, but DON'T BEND THE OIL PIPES!!
 Then flushing the coolant system daily for 2 or 3 weeks....
 Indeed do not bend the pipes - its easier to loosen them - more on that if you decide to go with it.
 To be honest ive just done this and after getting the correct tools the most annoying part is the flushing. Which seeing as it lasts a few weeks you would have to do anyway.
 Cost £125 with trade card  :y
				What year/month did Vauxhall start fitting the modified oil coolers????
				about 95/96......not many Omegas got the old version.....it was mainly Cavaliers that suffered...
 The key thing that kills them is irregular coolant changes and the wrong anti freeze mix.....
				Andy,
 Is this the one on ebay?
				Yes we are just about to take it off ebay and attempt a repair as a car I was going to buy as a replacement has fallen through
 good man - on attempting the repair - keep us posted of things  :y
				Don't worry I am sure I will be on here a lot with pictures and screaming for help!!!!!!!
 Going to photograph my progress and post it so you can keep track with me and help when it all goes Pete Tong!!!
 Whilst I have all the decks cleared to do this is it worth doing the timing belt????
 If so any intsructions greatfully recieved!!!
 Pm member Robin Hood and buy the DVD for 3 quid....
				1st question!!!
 Doing quite well at the moment everything seems to be coming off easy enough!!!
 on the exhaust recirc on side of plenum presume I need to remove the gaurd around throttle cable to acces the third bolt????
 also have no "black things to remove to remove the 4 torx bolts are these the four that sit on top of the plenum???  am using vectrolosys instructions
 http://www.vauxhallownersnetwork.co.uk/showthread.php?t=63566
				Black things are missing I guess...
 As for EGR rmoval.....undo the bolt union (24mm) where the flexi pipe joins the EGR base and remove the single torx bolt on the bracket next to it rather than disconnecting it from the plenum.....coz it saves a gasket and gets it out of the way....
				progress so far rained off today  >:( >:( >:( >:( >:(
 (http://)http://i193.photobucket.com/albums/z262/andycuk16/Picture003.jpg
 (http://)http://i193.photobucket.com/albums/z262/andycuk16/Picture002.jpg
 (http://)http://i193.photobucket.com/albums/z262/andycuk16/Picture001.jpg
 Ah, I disconnected mine the other day, should I have put a new gasket in then? presumably that's the funny shaped thin metal bit between the EGR and the plenum?
				Do yourself a favour Andy and put some rags in the inlet ports.  You will hate yourself so bad if you drop a bolt down there :o
				do you need to change the thermostat whist doing oil cooler???
				not essential, but i would - well its only £20 odd quid and your there anyway   :y
				oh and make sure if you do replace it you get the new rubber seal and 2 new bolts - the lip on the new vx thermostat to replace the old one is different - meaning that although the bolts will fit and torque up they will be " swimming"....
 If you have issues sourcing the new bolts ( as they dont come with the stat) i am sure i can find the part number when i get home for the compatible bolts  :y that is unless M DTM knows them off the top of his head  ;)
