Omega Help Area => Omega General Help => Topic started by: wheelchairkid on 21 May 2007, 13:19:37
Hi to all
I have got a 2001 X reg Omega Elite, 2.6 auto estate. it has the digital climate control, but no matter what I do, I can not get warm or hot air to com out of the drivers side vents. it gets nice and hot in the passengers side and the back. Have any of you got any Idears on what it could be?
Yours
Jason :'(
Have you tried the reset servo procedure, press and hold off and auto for a few seconds, you know its worked, you hear the motors going.
After that, I dunno. loose pipe or something?
...if after that it does not work then its onto the temperature control servo on the drivers side of the heater assembly in the drivers footwell
Hi tried resetting the servo`s, no good, but I then looked in the drivers footwell, and found a thin black plasitc rod with two holes in the end, not conected to any thing, but when I pul the black rod down I get hot air, so all I need to know is what should it conect to, and what does it look like?
Yours
Jason :y
Had the same problem on my facelift omega. Check this link: http://www.cavweb-forums.co.uk/showthread.php?t=118890 :y
