Chat Area => General Discussion Area => Topic started by: JamesV6CDX on 18 September 2007, 22:25:46
Title: EGR blanking plates
Post by: JamesV6CDX on 18 September 2007, 22:25:46
Who was doing them? Any available?
Title: Re: EGR blanking plates
Post by: Darth Loo-knee on 18 September 2007, 22:30:34
Why would you blank the EGR James? I have read that people do it just wondered why :y
Post by: JamesV6CDX on 18 September 2007, 22:34:19
No significant performance or economy gains but, sometimes the valve can stick, and this can eliminate this.
Remember all the EGR does is allow some exhaust gasses back into the combustion process, to help save the planet...
Post by: Bo Bo on 18 September 2007, 22:57:53
It was issunnaz  :y
Post by: omegalord on 18 September 2007, 23:01:26
Ive been told that blanking the egr off makes the car do more mpg and run better.
Im going to do mine with a coke can
Matt
Post by: IrmscherKris on 18 September 2007, 23:06:50
Last time I did mine...
2 x 5p's
Removed flex pipe (was leaking)
used the nut off it and bolted back on with the 5p's and a little exhaust putty...
Post by: omegalord on 18 September 2007, 23:07:33
Did it do more mpg and run better?
Matt  ;)
Post by: IrmscherKris on 18 September 2007, 23:10:06
Not that I noticed, but my driving goes from one extreme to the other day to day.  :y
Post by: Andy B on 18 September 2007, 23:44:36
Matt  ;)
Mine has one of the issunnaz excellent blanks. The fuel ecconomy is still sh1te.  :o  :y  :y
Post by: STMO123 on 19 September 2007, 07:12:53
That car's had one on before James. I didn't notice any difference in mileage/performance.
Seem to remember undoing the bolts with my '£1 shop star keys' :y ;D
Post by: Marks DTM Calib on 19 September 2007, 08:14:38
Thats a little hopeful.....it definately WONT improve MPG, it should help throttle response if you floor it whilst cruising....(because you dont have the minimal lag associated with the EGR closing)
Post by: cem_devecioglu on 19 September 2007, 09:37:57
Hi,
in my case
half a liter / 100 km better fuel consumption was easily measurable..
Car goes really better ..
Post by: TheBoy on 19 September 2007, 09:55:47
Matt
I think you'll find it will marginally worsen the mpg (in effect, the egr reduces engine cc when cruising).
Not sure about the performance, unless the egr is shot  :-/
Post by: Kevin Wood on 19 September 2007, 10:01:44
This is true. Exhaust gases in the inlet allow the engine to run under light loads without being so far throttled back so the pumping losses associated with a large engine under light throttle reduce and they also promote more efficient and complete combustion.
Under full load the EGR system is disabled so blanking it will make no odds to performance unless the valve was bust in the first place.
Post by: Markie on 19 September 2007, 11:10:22
potentially sorts out idle if its a little shakey.. :-/
Post by: TheBoy on 19 September 2007, 13:00:36
If the valve is knackered, it will cause lumpy idle, so blanking will cure that
Post by: MartinP on 19 September 2007, 21:07:19
If I haven't got any in the garage, I can get some more made   ;)
