Omega Help Area => Omega General Help => Topic started by: donna-marie on 21 May 2007, 10:55:09
Title: Thermostat
Post by: donna-marie on 21 May 2007, 10:55:09
think i need a new one for my 2.5 CD v6, temperature going to Red now, fan is cooling it down, loosing no water from radiator so me thinks thermostat. Could i do it myself?
Title: Re: Thermostat
Post by: Marks DTM Calib on 21 May 2007, 10:57:47
If the fans are cooling it down then the stat must be opening ergo...the stat is ok.
Have a quick look in the engine bay ECU box (on the right) and check the two 20A fuses for the two front mounted fans....
Post by: donna-marie on 21 May 2007, 11:01:04
they look ok, should i replace anyway, i sell automotive consumables (office based) so i'll pick up an assortment and replace all.
Post by: Admin on 21 May 2007, 13:37:57
Does the temperature climb rapidly when you are stationary and stay lower when cruising?
Post by: hotel21 on 21 May 2007, 13:41:20
If I said that mine has a sometime tendancy to do this, then what would that mean??
Post by: Admin on 21 May 2007, 13:42:48
I would say when was your water pump last changed?
Post by: hotel21 on 21 May 2007, 13:43:48
About 15k miles ago with the belt and tensioners....
Post by: Marks DTM Calib on 21 May 2007, 13:49:28
I wouldn't, I would sudgest a good coolant flush and given the good results with the Forte stuff.......
Post by: Admin on 21 May 2007, 13:54:33
And Marks idea is cheaper and easier to do first.... ;)
Post by: Markjay on 21 May 2007, 15:43:33
Just for info, on the V6 you will need to take-off the intake plenum, intake manifold (with injector rail), and intake flange, in order to gain access to the thermostat housing. The thermostat itself is slightly more exepnsive than usual due to the fact that it comes with the housing. So while doable, it is time consuming and should only be done after other more likely/trivial causes have been ruled out as suggested above...
Other than that follow the advice from Mark DTM / Laidback66 / TheBoy and you can't go wrong  ;)
Post by: donna-marie on 21 May 2007, 16:35:55
Ye the temp is around 95-97ish when crusing but as soon as stopped in traffic goes to RED then starts vapour up side of bonnet driver side. All levels of fluids are correct.
Post by: Marks DTM Calib on 21 May 2007, 16:50:08
Can you hear the engine cooling fans kicking in.....
Post by: donna-marie on 21 May 2007, 16:51:51
yep but not till hitting red
and theres a bad smell (rubber) for a few moments then goes off
Post by: Markjay on 21 May 2007, 17:01:26
Looks like fans kick-in too late?
Faulty thermoswitch...? or blocked / airlocked rad preventing coolant from circulating to the thermoswitch area...?
Post by: TheBoy on 21 May 2007, 21:25:53
I can vouch that the Forte Cooling System Flush is very impressive, far better than the Holts type stuff....
Post by: Markjay on 21 May 2007, 23:08:26
Just bought two bottles of Holts at Halfords for the summer coolant change  >:(
Post by: Markie on 21 May 2007, 23:40:23
where did you get this renowned stuff....
Post by: Marks DTM Calib on 22 May 2007, 08:15:00
There are two types, a coolant flush and a bio de-greaser, you want the coolant flush for a standard coolant change....the bio-degreaser works well after oil cooler failure.
Post by: Gaffers on 22 May 2007, 14:44:23
ditto  >:( :-/ :'( :-[
Post by: Marks DTM Calib on 22 May 2007, 15:42:45
This for the oil cooler cleaning...
http://cgi.ebay.co.uk/Forte-Bio-De-Greaser_W0QQitemZ120001913941QQihZ002QQcategoryZ122141QQcmdZViewItem
This for the standard flush
http://cgi.ebay.co.uk/FORTE-Cooling-System-Flush_W0QQitemZ330077166914QQihZ014QQcategoryZ25632QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Post by: JamesV6CDX on 22 May 2007, 21:28:06
Gloucester - I work there, so would save the £5.50 postage
Just wonder if enough of us were interested, maybe we could negotiate a bulk buy for the forum...
