Omega Help Area => Omega General Help => Topic started by: martinj75 on 24 May 2007, 11:55:14
Title: heated seat
Post by: martinj75 on 24 May 2007, 11:55:14
 :hi there i have a 1999 2.5 v6 omega est. the only problem i have with it is the drivers heated seat. it dose not work i have checked the fuses and i carnt see a blown one. i have switched the swiches over and that dose nout as well. plz help as i have back troubel and i miss my heated seat . thanks. martin
Title: Re: heated seat
Post by: Paul M on 24 May 2007, 12:17:05
Hi and welcome.
Unfortunately it's probably the heating element inside the seat that is broken. It seems to be quite a common problem as the car gets older, particularly the driver's seat as that's the one that is most often used (that is, someone sitting in it, doesn't matter if the heater is switched on).
Non-leather interiors are quite cheap from scrappies or people breaking cars so the easiest fix is probably looking for a replacement seat with a working heating element.
Post by: TheBoy on 24 May 2007, 12:44:24
Yes, as Paul M says, likely to be one of the heater pads or the thermostat bit in the seat....   ....replacement of the pad, though possible easier to get replacement seat...
Post by: Elite Pete on 24 May 2007, 14:25:20
I belive the element is easier to replace in the cloth seat than a leather one.
Post by: TheBoy on 24 May 2007, 14:41:22
I was under the impression that leather couldn't have the pads replaced, then I found how on TIS...
Post by: Andy B on 24 May 2007, 19:08:28
....... then I found how on TIS...
So  .... what does TIS say?  :-?  ;)
Post by: TheBoy on 24 May 2007, 19:26:10
I'm sure someone can dig it out, I've gone and uninstalled it for some stupid reason that is unknown....
