Omega Help Area => Omega General Help => Topic started by: Tony O on 02 May 2007, 07:48:22
:-[ Is it possible to program keys without car pass, local stealers are unable to find the number for my 95 CD. It seems no codes were used befor 95 and mine is a 94 spec. Can it be done using Tech2. Please help I am now 3 weeks without my omega and I am getting cramp driving my daughters Mini.
Sorry, don't know. Being an early one, it is probably infrared, not rf. Tech2 cannot do IR remotes (need a Tech1). Whether or not it can do the immobiliser is a different story, and I would need to try to find out (I know it can read some early immobilisers)...
I find it rather strange that you own a car, quite legally, and can prove this, yet the manufacturer cant give you the means to start it! rather nonsense >:(
I have spoken to another dealer ( 200 miles away ) and he finds it strange the number can not be found. he is going to look into it for me. other than that I may take the switch from the good key and put it in the duff key to see if that works.
Or bypass the immobiliser......if its an IR setup ::)
How do you do that :question
That is one to keep out of public forums methinks....
Can you either email the info or email your address & I will send stamped envelope for details.
Will send details at the weekend
Big Thanks.
:y makes sense
Still no joy with the car pass number, did Mark post the info as I have not recieved anthing & I am close to giving up. I don't want to lose the car but I can't fit the family in the mini. Please please please HELP.
No I didn't and thanks for the prompt....I will try to get it done this evening.
Thanks Mark
.... and mine? pretty please! ::) :y
Oh no I have taken kick plate off but there is only one box there I assume this is the central locking what now???????????
Have a look up behind the fuse box....look for a larger relay.....
OK I will look after work. What do I do with the relay?
I have taken out the fuse box & there are two relays cant quite see what size although one is green & one light blue, there is also a conector strip with the following wiring.
Top from left to right: Grey,Brown,Brown,Red
Bottom : Red,Black,grey/yellow,Black
What now?
HELP what now
You need to give me chance to consult my 'bible' this pm...... :y
Big thanks Mark, sorry to be a pest but I am now without wheels as the mini's wiper moter has just packup during it's mot !!!!!!!!!.
Thanks again.
Ok, remove the glove box....behind here you will find a bank of relays, one of which is pretty big (K117, top row), it should have the wires described entering the base of the part...
I will have a look asap, i assume these are the wires in the email. Big thanks
Yipee! Mark your a genius & a legend in your own bathtime many many thanks.
If your ever down this way I will buy you a big drink. Thanks again
It worked then.....
Yes started first time as well. Thanks again.
