Omega Help Area => Omega General Help => Topic started by: tunnie on 25 May 2007, 18:44:37
Title: spanner light + no power (now with codes)
Post by: tunnie on 25 May 2007, 18:44:37
You may remember my 2.2 Omega had a problem yesterday, starts fine, idle too high at 1,300 RPM, spanner light was on, pressed the gas pedal nothing happened .
Got the codes (thanks to Jaime for reading them even when he had family around  :y)
P1550 - Electronic Throttle Control Motor
P1500 - Electronic Throttle Control Motor Failure
P1525 - Limp Home Position Error
Once warm, the enging was fine. Problem has not come back, even after another cold start.
Throttle body and breathers cleaned last summer....
Title: Re: spanner light + no power (now with codes)
Post by: Craig_R on 25 May 2007, 18:48:15
I hope it was just a clitch on your throttle body tunnie as they cost a fortune the DBW ones i have seen them on ebay for about 230 quid but i did see one once for 20 quid.
Fingers crossed for you tunnie it will befine from now on  :y
Craig
Post by: tunnie on 25 May 2007, 18:50:36
Craig
Cheers m8, Jaime was saying the same....
Maybe its a good excuse to swap it for a V6  ::)
Post by: Auto Addict on 25 May 2007, 20:13:25
Before you jump to too many conclusions, I would clean up the electrical contacts to the throttle control motor, with a good contact cleaner.
I seem to remember MarksDTM saying he's never know one to fail yet, of course there could always be a first time, but fingers crossed.
It won't do any harm to clean up the throttle body and breathers again, it's not a difficult job.
Post by: Chopsdad on 25 May 2007, 21:30:27
Mark also suggests cleaning the MAF contacts with computer foam clean :-?
Mine ran excessive rpm last year Tunnie after I'd cleaned the breathers, turned out to be nothing more sinister than a sticking butterfly.
Post by: tunnie on 25 May 2007, 21:37:59
Got sneaky feeling thats that might be it...
First job when i get back after the trip this weekend is to give the Omega some love and attention  :)
Post by: Bernard on 26 May 2007, 02:39:06
Not Adviseable to to clean with Computer foam clean as this is Water based ! Far better to use Electrical Contact cleaner. :y
Post by: Auto Addict on 26 May 2007, 08:33:45
IIRC tunnie, have you cleaned out that back breather pipe at the back of the camcover, the one you couldn't get off?
Post by: Marks DTM Calib on 26 May 2007, 09:36:16
As I originaly said....sticking throttle.....its been sat dry for a few weeks, stuck shut and the ECU stuck it in de-stick (max thrutch to the actuating motor) and then limp mode....
