Omega Help Area => Omega General Help => Topic started by: Darth Loo-knee on 31 May 2007, 22:54:36
Title: Started first go Guys!
Post by: Darth Loo-knee on 31 May 2007, 22:54:36
Went out this morning at just after ten started up first time after the petrol had got through ;D
Slight tapping for a few seconds and a bit of smoke out the back (oil going down the cylinders when changing spark plugs) for a few secs then lovely and quite :y
Done about 50 miles in her today but when i lifed the bonnet I could heard a hissing coming from the  Coolant Resevoir Cap is this right or do i need another cap????
Thanks for all your Help Guys ;)
Title: Re: Started first go Guys!
Post by: gizza on 31 May 2007, 23:20:55
i had a hissing sound coming from my 2 ltr when stopped with the engine off and the hbv went in a big way does it lose any water, the hissing sound was air being drawn in through the hbv and then finding its way up to the expansion tank, also the car would smell of hot coolant after a long run i couldnt see any leaks under the car and was only losing a small amount of water before it let go, but try going to a scrappy he may well give you a 2nd hand cap for next to nothing and try that
Post by: Markie on 31 May 2007, 23:24:20
good work on the start !! but that hissing hmmmm - check levels, for leaks underneath and report back  :y
Post by: Darth Loo-knee on 31 May 2007, 23:31:38
Checked level it seems to have stayed where it is as for leaks dont be saying that :-[ don't want to be taking it bits again :'(
No water on the floor when i had parked, can't see anything under the bonnet..
Just that the cap is hissing....
Post by: Darth Loo-knee on 31 May 2007, 23:33:22
Just fitted a new HBV, but maybe an idea to get another cap :y
Post by: Mike Collins on 01 June 2007, 08:28:29
The expansion bottle caps on both my V6 have two valves, one I believe to be the overpressure relief and the other works the opposite way round. it allows air in when the system cools and the coolant contracts. I can often hears gentle hissing at the cap after shutdown.
A Halfords copy cap on the shelf has only one valve visible. I can't tell if has more than one function.
It has just occurred to me that if a HBV is drawing in air, could this be caused by no inlet valve in the cap?
Post by: ians on 01 June 2007, 09:45:32
You sure its the cap L-K?   The breathers when clean do hiss a bit.
Post by: Darth Loo-knee on 01 June 2007, 16:11:18
Glad about that i was gonna ask as i never heard them suckin like that ;D
Also the cap has stopped hissing now i have all the air out of the cooling system, i had not done it last night :-? so that is probably why ::)
Thanks Lads
Daz:y
