Omega Help Area => Omega General Help => Topic started by: korum on 15 June 2007, 21:21:28
Title: coolent level
Post by: korum on 15 June 2007, 21:21:28
Hi today while out and about my mid stated that the coolentlevel was low but after checking the resevour its at normal level??
Any ideas??
Thanks in advance
pete
Title: Re: coolent level
Post by: JasonH on 15 June 2007, 21:42:58
The sensor in the bottle can clog up (small float in the middle) but usually it's the connections underneath the expansion bottle.
Post by: TheBoy on 15 June 2007, 22:10:15
Yes, check the float in bottle is crudded (if it is, what is rest of coolant system like?), but most likely a knackered switch under the bottle caused by coolant spillage by a kakhanded mechanic. New switch is part of bottle, and not available seperately
Post by: Taxi_Driver on 15 June 2007, 22:18:17
And is about 40 squid......i know, mine is knackered too..... :(
Mrs AA asked why my mid was showng coolant level.....when AA was taxi'ing me and her goodself around  ::)
Post by: korum on 17 June 2007, 17:45:45
Thx all ill check that out.
maybe see if they have any at the local scrappers as i have a mega vaux just up the road
cheers
pete
Post by: Andy B on 17 June 2007, 20:19:55
cheers
pete
You'll find the scrap yard header tank is likely to be as bad or not far off as your old tank. A new one is more like £30 and when fitted looks the dogs danglies compared to the original dirty 'oribble brown tank. Definately worth putting your hand in your pocket for a new 'un.  ;)
