		Chat Area => General Discussion Area => Topic started by: Bo Bo on 24 August 2006, 00:42:03
				Due to shift work I have to do a lot of night driving & my headlights leave a lot to be desired.
I've tried a couple of xenon "upgrades", but to be honest although they looked good from the front, they were actually worse to drive with (espicially the blue ones).
I've done a bit of research & Ring Ultra Xenon seem to come up more than most.
So what's your views, what's the best wattage to go for & should you change the side light bulbs to match?
Cheers
				Stick to 50W (not sure if the 80W and 100W are street legal anyway?), but go for the uprated '+50' bright light ones.
 ...... (not sure if the 80W and 100W are street legal anyway?).......
They're not, but who's gonna find out?
Your wiring........
Upgrade the headlight earth connections to.....
Your wiring........
Without going into current draw against the size of the wire etc etc I had no problems with my Manta that had 80(85?)/100W lamps in or my last Senator that had 100W in the driving/spot lamps. No problems with the Omega's HID headlights - one of it's redeeming features! (although I might look at 100W in the driving /spots)
I agree....the +50 ones certainly make a difference, to the point where i'm just about happy with them now.
I was going to convert to HID's but its quite involved to do it correctly.
You could of course by a HID kit off ebay.....altho fitting these kits would still be illegal....as the kits ive seen dont make the headlight units auto tilt or have headlamp washers.
Cheers
Your wiring........
Like it.... ;D
				The '+50' seem to be recommend, to the point that I would use them if I didn't have HIDs  :D
The 'Xenon' upgrade standard bulbs are worthless.
You're right, the Xenon standards are worthless & in the case of the blue ones I tried; actually worse.
I got the 50% brighter bulbs & there is an improvement, not brilliant but much better, although I wouldn't say they're 50% better!
