Omega Help Area => Omega General Help => Topic started by: Elite Pete on 20 June 2007, 18:23:35
Title: Power steering problems
Post by: Elite Pete on 20 June 2007, 18:23:35
My power steering has started to play up. It started yesterday when my wife was using the car (theres a suprise) she said the steering goes heavy when she goes around corners so I thought it could be low fluid. I got home tonight and had a look and the fluid is at the correct level and the reason the steering goes heavy around corners is because the engine revs are low, if you rev it the steering gets lighter. So do I need a new power steering pump?
Title: Re: Power steering problems
Post by: Dave-C on 20 June 2007, 18:28:46
Pete, mine went through a spate of this, been Ok since I changed the aux belt....   might it be just slipping????
Dave C
Post by: Elite Pete on 20 June 2007, 18:38:09
Hi Dave
The belt was a new genuine part when I did the cambelt a couple of months ago.
Post by: Elite Pete on 20 June 2007, 18:39:38
Hi Dave
Just had a thought. I suppose it could be the aux belt tensioner though
Post by: Dave-C on 20 June 2007, 18:49:59
Mmmmmmmmmmmmmmm, Maybe...
DC
Post by: TheBoy on 20 June 2007, 22:19:02
All the symptoms of a tired pump, as you thought... :(
Post by: Elite Pete on 20 June 2007, 22:34:27
Cheers TB
Post by: Elite Pete on 20 June 2007, 23:08:34
Am I right in thinking the 2.5 and 3.0 pumps are the same.
Post by: TheBoy on 20 June 2007, 23:09:30
i believe so...
Post by: Marks DTM Calib on 21 June 2007, 08:23:25
Yes they are....a good second hand unit is the way to go.
Post by: Elite Pete on 21 June 2007, 10:17:48
Cheers Mark
How easy is the power steering pump to remove and do you have to bleed the pump?
Post by: Marks DTM Calib on 21 June 2007, 10:19:22
Its pretty easy to get out, only three bolts.......and bleeding the system is easy as it simply involves turning the steering wheel with the engine running.
Post by: Elite Pete on 21 June 2007, 10:21:17
Thanks Mark :y
Post by: Elite Pete on 21 June 2007, 22:05:05
I nearly went sideways over a roundabout today. I had to go out in the Omega and the power steering was not working at all so I wrestled the old girl for about 7 miles in the pooring down rain until I came to a roundabout looked right nothing coming so I gave a good tug on the wheel and the bloody power steering decided to work :o a bit of unexpected sideways action and a skiddie in the trolleys. now the power steering has worked as it should for about 12 miles in total. whats going on :-/
Post by: Marks DTM Calib on 22 June 2007, 11:05:11
Check the fuse is ok and not hanging half out...
Post by: Elite Pete on 22 June 2007, 11:36:43
Thanks Mark I will have a look. Im off in to Chester now which should be fun, every corner will it or wont it ::)
Post by: Dave-C on 22 June 2007, 17:01:30
Can I come with you, Alton Towers is too expensive....  Would love a white knucler  ;D ;D ;D ;D ;D ;D
