Omega Help Area => Omega General Help => Topic started by: pete1666 on 20 June 2007, 16:36:46
Title: Oil Lack and Coolant level
Post by: pete1666 on 20 June 2007, 16:36:46
Hi can anyone tell me why i have oil lack and coolant level warnings
they are both full , it dont use water or oil .
Cheers Pete
Title: Re: Oil Lack and Coolant level
Post by: Dazzler on 20 June 2007, 17:14:29
try a system reset......
Post by: pete1666 on 20 June 2007, 17:19:44
How do i do that?
pete
Post by: Marks DTM Calib on 20 June 2007, 17:32:18
Yes, how do you do that.... ::)
Post by: Markie on 20 June 2007, 17:57:34
oil lack, thats a bit more serious than the oil low warning is it not?  :-/
Post by: Gaffers on 20 June 2007, 18:00:51
I would be interested in knowing that too.....
I had the same problem with 'oil lack' - dejunked with some flush not had it since.  Sometimes the sensor can get covered in crud esp if oil changes not done regularily.
Check you coolant sensor in the header tank.  If it moves freely up and down I would suspect a rogue wire or two...
unless you take corners at 6G ........   :o
Post by: ians on 20 June 2007, 18:38:23
I don't know the answer, but is there a clue in the fact that he is getting both these messages in error.   Either big coincidence , or some common factor..
Did both messages start appearing at the same time, and was the fluid in need of toping up?
On mine 'Oil Level' comes on at about midway down the dipstick (.5 L of max).  Presumably Oil Lack is even lower.
Post by: TheBoy on 20 June 2007, 22:18:15
Either both sensors (oil level sensor and coolant sensor) have simultaneously failed, or the plug has dropped out back of MID (assuming 2 plug variant). Or you've fitted a MID into a car with a TID, and hence no sensors...
Post by: pete1666 on 21 June 2007, 00:16:06
hi the MID and the TID can you explain a bit more, i did change the engine
recently but i took 2.5 V6 from a 95 gls saloon and put it in a 96 CD Est?,
all was ok on each before the change.
Cheers Pete
Post by: TheBoy on 21 June 2007, 08:48:45
Cheers Pete
ah, gls engine wont have oil level sensor.
for coolant, check the plug under coolant bottle is plugged in
Post by: pete1666 on 22 June 2007, 09:22:09
hi is there any way of stopping the oil lack coming up of fitting a sensor..
Post by: TheBoy on 22 June 2007, 14:13:21
Fit the level sensor ;)
Post by: pete1666 on 22 June 2007, 18:58:56
hi where does it go and will there be wiring for it and is it easy to do???
Post by: Markjay on 23 June 2007, 00:04:17
It goes inside the bottom of the sump... so you need a sump with a sensor. Sump-off is engine-out job on V6 though you may be able to get away with undoing one engine mount and tilting the engine up - either way so not a simple task as such.
