Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 25 June 2007, 10:21:57
How is it done? I was hoping I'd open the door and see some bolts... but no!!
Desperately want to change my front OS door...
Disconnect the check strap, disconnect the wiring (big plug on front doors, small plug in B post on rears) and knock the pins out...
....watch out though, they are V-heavy
Pins look flared at the ends.. do I need to do something with this?
What about re-fitting, any special tools etc needed?
They are flared at the end........at least you knwo which way to remove them.
As for re-fitting....a hammer works well.
I used a blunt chisel & hammer, it was all I had but it worked ::)
Just make sure everything's lined up when knocking the pins back in.
Make sure the multi-plug connectors are the same, the first door I tried was different & didn't realise until the door was off.
SP do a kit for this, only about £15ish, it consists of a pin that has a screw on end which you slide through the hinge pin and then screw the end on, then you have a 12" bar with a slot at one end which you place over the pin you have inserted and stick down on the bar which in turn will extract the pin :)
I have known some people to do this job with a pair of molegrips, clamp the pin as hard as you can to compress it slightly then hit the molegrips down to withdraw the pin.
I prefer the proper tool for this job, if you were closer you could borrow it, but i'm sure someone closer to you will have one ;)
....watch out though, they are V-heavy from DTM
Yes they most definetly are - better use 2 people .
If you are doing it in your own mind your toes when it drops - cus it will
As other have said be very careful I changed my passenger rear door and nearly did drop the thing on my feet.
I managed to use a set of mole grips wedging a cole chisel underneath and then using a club hammer knocking the cole chisel down or upwards which ever pin I was doing forcing the pin out.
Its a great feeling once fitted, still have a passenger front door to change at some point.
It might be worth getting the trolley jack out with a rag or piece of timber to take the weight.
Get a second set of hands, and not Mrs JV6CDX, as the door is heavy as others have said. Job for when your mate Markie is about....
She's probably stronger than me ;D ;D
Dazzler's right ,buy the Sycks Pickavent split roll pin removal tool it will do the job first time and every time.
Ep's idea with the trolley jack is a definate yes too, you just need some steadying hands.
I did it this way when removing incredibly heavy doors from a '57 Opel Rekord.
Don
