Omega Help Area => Omega General Help => Topic started by: pete1666 on 01 July 2007, 16:05:38
Title: OH BOLL"&$S
Post by: pete1666 on 01 July 2007, 16:05:38
Just went to check my oil levels and mayo lots of it and to top it off oil in the water too, but i havnt lost any water,
and it sound like there`s an air leak, but it start on the button and ticks over
at 500 rpm.
Is this just the oil cooler or are the heads going too??
Help!
Pete
Title: Re: OH BOLL"&$S
Post by: JamesV6CDX on 01 July 2007, 16:48:14
Is there Mayo on the dipstick??
Smell of exhaust in header tank?
If it's just mayo in coolant, it's likely to be oil cooler.
Post by: Marks DTM Calib on 01 July 2007, 16:55:13
Its pretty much impossible to get oil into the water via the headgasket on a dry liner engine......so its probably oil cooler....mayo in the filler will be condensation.
When you say oil in the header tank, is it just a small trace on the surface or is it like mayo because oil cooler failure turns it into a mayo!
Post by: pete1666 on 01 July 2007, 17:11:49
There`s no mayo on the dipstick, i`ve put my finger in the header and
it is mayo i know the oil cooler has gone but concerned with the mayo
in with the oil as this is the first time i`ve had any there and i only do
short journey`s, would this be a cause for 21 mpg??
Post by: Marks DTM Calib on 01 July 2007, 17:42:50
Well you need to consider the way the coolant system works.....when running, the engine oil pressure is much greater then the coolant pressure so oil is forced into the water under oil cooler failure scenarios. When the engine is off, the water stays pressurised long after the oil pressure has dropped away...hence some water can get back into the oil.
But, mayo in the filler neck is most likely short journeys.
Mayo in the header tank is oil cooelr failure.
Post by: pete1666 on 01 July 2007, 18:41:12
Anyone  got a good oil cooler  i can have pref a SS one.?Please ;D ;D ;D
Pete
Post by: TheBoy on 01 July 2007, 18:43:08
Pete
Don't faff around with second hand ones, get a new one. About £90 IIRC for cooler kit...
Post by: pete1666 on 01 July 2007, 21:45:20
Pete
 Yes but the car cost £150 then the cam belt went got another for £100 changed the engine
then sold spares for £170 so far  so spending £90 seems a bit rich, i still think i can run
it for peanuts?
Post by: TheBoy on 01 July 2007, 21:51:36
In that case I would suggest you trawl the scrapyards.
Post by: Jimbob on 02 July 2007, 08:39:35
Pete
Bugger, just chucked one out, not good, but not bad either.
Was taking no chances with my water leak.
Post by: Marks DTM Calib on 02 July 2007, 08:59:27
Its a 50:50 chance that you can remove the securing nuts without stripping the threads......I personaly would go new....
Post by: Martin_1962 on 02 July 2007, 09:37:39
Just because the car was cheap doesn't mean it is not worth spending money on
Post by: Kevin Wood on 02 July 2007, 10:17:27
Very true.
Cars are cheap for a variety of reasons but when you spend money maintaining a car you are paying to have a reliable vehicle you can depend on, not sinking money into something that will never pay you back. I don't understand the attitude of "it only owes me £xxx" when it comes to mainenance. Regardless of whether your car cost you hundreds or thousands in the first place you need to spend a certain amount on servicing and repairs if you want to be able to depend on it, just as you have to spoend money on petrol if you want to drive it. Scrimp on this and you'll have a car that will let you down.
An item like the oil cooler is a common failure and the likelihood is that a part from a scrap car will be well into its' limited life. The amount of work involved in replacing it and cleaning up the mess in the cooling system doesn't warrant risking the possibility of fitting a duff one, or one that will maybe last 6 months and then leak again, in my eyes. Had it been an item that isn't notorious for failing, or one that's a 5 minute job to fix, an item from a scrappie would be worth a punt.
Post by: Marks DTM Calib on 02 July 2007, 10:26:29
Not so, the oil cooler is only a common failure on poorly maintained cars....i.e. those with poor coolant changes and where the anti freeze mix is not maintained at 50:50 and this happens when people top the cooling system up with water and not a ready mixed anti freeze solution.
If you do go down the second hand route then as said, be aware that you need to ensure that the plate securing nuts remove cleanly as they have a habit of stripping the threads off the oil cooler on removal...
Post by: Ronald_McBurger on 02 July 2007, 10:41:09
I have a brand new oil cooler. I say brand new, it was brand new and fitted to the project LPG elite. I removed it when I stripped the engine. The nuts are not srtripped and it is new. Let me know if you are interested. Was going to keep just in case, but I have no more planes de-la-Omegas.
Post by: Markjay on 02 July 2007, 13:29:42
Mine went when the car was (luckilly) still under the original 3-years warranty... but then again it has been serviced by Vx annualy beforehand so this may explain it..  >:(
Post by: pete1666 on 02 July 2007, 17:28:18
Pete
just been down to VX £90.50 + VAT  anyone got a trade card or know how to get one?
Chers Pete
Post by: pete1666 on 02 July 2007, 17:39:10
Hi just flushed the rad, i have a nice baby poo color liquid flowing out slowly. done it a few times still a bit
in there filled it back up and run it,
I cleaned out the oil filler cap and and while it was running i open the oil filler cap and it was steaming
 a little and there`s droplets of water on the cap is this normal when the oil cooler goes??
Pete
Post by: Kevin Wood on 02 July 2007, 19:20:04
I've seen good engines steam a little bit from the oil filler when warmed up. Some water does get into the oil in the blowby gases and is removed as vapour by the breather system in due course. In addition, a little water may have been leaking into the oil through the failed cooler after shutdown when the cooling system is left pressurised so I'd say it's no cause for concern. Give it an oil change when the cooler is fixed for good measure.
Join Autobahnstormers is the quickest and easiest option if no-one in your area has one already. 20 quid for a year. Or see Ronnie's post above.
Cheers,
