		Omega Help Area => Omega General Help => Topic started by: redrover820 on 29 June 2007, 18:47:10
				Hi, love the warm weather, 2002 omega 2.2 hates it.....
 If the outside temp is above approx 12-13 deg` cent` the cold start will be lumpy for about 10-12 secs before alls well. Above 18-20 deg` cent` the engine will stall and require a second go then very lumpy for 10 -20 secs.
 During winter the problem went away & warm start has never been a problem.
 Any advice will be appreciated. thanks.
				Clean out the ICV ;)
				Hi. found out today that it was a cracked exhaust manifold.
 The crack closed up when the engine got warm and the metal contracted ( closing the crack ) in cold weather.
 But you all knew that......
 Common enough, but usually you can hear that fault...
