Omega Help Area => Omega General Help => Topic started by: omegalyn on 09 July 2007, 08:40:23
Title: Cabin Blower
Post by: omegalyn on 09 July 2007, 08:40:23
Hi there folks,
I can't seem to get the dash fan to blow out through the centre grill (the setting that blows on your face.) It sometimes works when I fiddle around with the switch from foot setting to windscreen and back to centre, or if I bang the top of the dash, (and look like some kind of nutter to other road users) and when I get it to blow out of the centre grill, the next time I use the car its back to blowing to feet or screen even thou the switch is on centre grill setting.
Any one else had this problem.
Thanks
Title: Re: Cabin Blower
Post by: Marks DTM Calib on 09 July 2007, 08:49:08
Sounds like an iffy vac pipe connection to the rear of teh selector switch.....given how reliable these are it sudgests somebody has been in there before
Post by: omegalyn on 09 July 2007, 08:58:22
Thanks for that, can I replace this switch, what dose it involve. Have had a look behind the switch leaver and there is one screw, is it just a matter of undoing this, or is it a dash dismantle.
Thanks again,
Lyn.
Post by: spookyman60 on 09 July 2007, 09:12:21
its not climate control is it ?? if it isnt then u have to remove the radio and switches and above the radio and the tc to the left of the radio then remove all the other nobs for the blower then a screw just above the ashtray when u open it at the back theres a half moon when u look at it hth i can grab a u a few pics as i can disamble it in about 10 minutes now
Post by: omegalyn on 09 July 2007, 10:19:48
Thanks Spookyman
It's this type of dash, got off the bay
http://cgi.ebay.co.uk/VAUXHALL-OMEGA-2-0-16V-GLS-12-MONTHS-MOT-6MONTHS-TAX_W0QQitemZ320135303636QQihZ011QQcategoryZ9858QQrdZ1QQcmdZViewItem
Post by: spookyman60 on 09 July 2007, 12:32:54
sorry its takeing so long im haveing trouble with my phone but its sorted now
Post by: spookyman60 on 09 July 2007, 13:43:54
nope it still not doing what i want it to do :( il sort them out by tonight i hope i have the pics and videos but there on the phone im extremely sorry
Post by: omegalyn on 09 July 2007, 15:22:34
That’s ok spookman, Its always the same when you want something  :y
Post by: spookyman60 on 10 July 2007, 06:38:09
right ive managed to just about get a few pics but not as many as i wanted to get up so here goes the vids wouldnt encode at all for some strange reason
if ur radio is coded make sure u have the code or what ever because it will need removeing
this is what mine looked like b4 i removed it
(http://i175.photobucket.com/albums/w148/spookyman60/25052007012.jpg)
remove the switchs witha screw driver both sides as u can see im haveing to hold the camera and i couldnt do it and gentle prise out the switch like so
(http://i175.photobucket.com/albums/w148/spookyman60/09072007053.jpg
now when u get to the hazard switch u have to remove the cap u will think u have broke it but u havent there is 2 tabs left and right of the white centre bit u have to push in to get it to move then gently pull out
(http://i175.photobucket.com/albums/w148/spookyman60/09072007055.jpg)
ten remove all the knobs off the heater matrix and then it should look like this there is a screw under each one
(http://i175.photobucket.com/albums/w148/spookyman60/09072007050.jpg)
then removeing the ashtray take out the ashray that removes to empty the ash then the screw at the back of the ashtray
(http://i175.photobucket.com/albums/w148/spookyman60/09072007052.jpg)
now pull the ashtray out and then the face should come away then slide the plugs off the back of the facia push them down if u have tc u will have to remove this switch as well by priseing out the blanks first then the tc switch its self then remove the plug from the back of these then remove the plug at the back of the main fascia this should then remove the entire section of the centre console facia hope this helps plz add to this if i have forgoton something
Post by: omegalyn on 10 July 2007, 08:22:26
Thanks for the guide, you are a man of your word and an early bird. I shall have a go when I know more about how the switch actually works, now I know how to get one out from a scrap yard.
Thanks again for the great pics. Maybe you should post them in the how to section.
Thanks again.
Lyn.
 :y :y :y
Post by: spookyman60 on 10 July 2007, 09:04:51
no problem at all my friend although i cant post anything in the how to section which is a crap but if some one else would like to post them to the how to and use my links as my photobucket wont change as i use it just for the car pictures
