Omega Help Area => Omega General Help => Topic started by: john1dart on 14 July 2007, 15:40:26
Fellas
I got home after work the other day and as soon as I switched the ignition off the main interior light came on. Never noticed before if this comes on when the ignition is switched off, or when the door is opened.
However, the light times out and goes off when the car is locked but, when the ignition is switched on the light will stay on until the ignition is switched back off.
I'm thinking faulty relay. Anyone had this fault or any ideas what it could be?
it may be a silly question but is the main light switch pushed in as this controls my interore light on mine
main light doesn't have a switch, the two map reading lights do, but a seperate to the main light
I think he means the headlight switch - as that controls the interior light...
Its not that, light goes off when alarm set.
Fellas
pop the light down, and check the 4 (?) connections are OK...
