Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 15 July 2007, 16:59:54
Title: Elite not starting
Post by: JamesV6CDX on 15 July 2007, 16:59:54
Just makes a VERY faint click, and nothing happens. Then will suddenly turn over and start fine.
Starter Soleniod dying?
Title: Re: Elite not starting
Post by: pete1666 on 15 July 2007, 17:16:08
It could be a loose earth or a loose wire on the started motor, i had the same
problem i checked a wire on the starter and it was only finger tight , i tightened
it up and probs since.
Post by: Kevin Wood on 15 July 2007, 20:16:31
Check the crimping of the wires to the battery terminal, too. Have seen a couple where this has come loose. Hot battery terminals when running are a give-away.
