Omega Help Area => Omega General Help => Topic started by: madmonk on 21 July 2007, 14:46:38
Title: Traction Control / LSD
Post by: madmonk on 21 July 2007, 14:46:38
Is Traction Control the same as LSD?   I want to change the differential oil but don't know if I have a limited slip diff or not, my Omega has traction control is this the same as LSD? if not how would I now if my car has LSD or not
Title: Re: Traction Control / LSD
Post by: Golfbuddy on 21 July 2007, 14:55:09
Just a thought bit you could put one wheel on the grass and the other on the road and try to pull away sharpish. If the wheel on the grass just spins I guess that would suggest that you don't have LSD. If you get good traction on the other side and she pulls away nicely then I guess that you do?
As I said, just a thought :)
Post by: Grumpy on 21 July 2007, 15:02:58
No they aren't the same thing.
LSD incorporates a clutch in the diff housing.
Traction control uses the anti-lock braking system to stop a skidding wheel
spinning.
Check the plate on your diff housing. On the bottom line of numbers, look at the second one.
If it is 'S' you have a LSD.
If it is '0' you haven't.
Post by: madmonk on 21 July 2007, 15:12:19
Thanks... I'll have a looook at the plate, failing that I'll try the grass and wheel spin technique  :y  cheers
Post by: TheBoy on 21 July 2007, 20:26:34
spinning.
Only the chances of that plate being readable is virtually non existent.
Unless it is a ex-plod, little chance of being LSD, unless specified by customer.
Post by: Markie on 21 July 2007, 20:35:11
almost no chance unless its less plod  :-/
