Omega Help Area => Omega General Help => Topic started by: Craig_R on 13 August 2007, 09:27:21
Hiya Chaps I wonder if anyone can point me in the right direction.
I have Bought a Cruise Control Box on Ebay for £15 with all the wires and so forth for fitting and i am waiting for a Stork to arrive also.
My question is about the brake and clutch switches
I will need a clutch switch which ill buy new from VX, Anyone know the part number and price of one ?
And the brake switch i already have but dont know if its the right one on my car, I think you need a 4 pin brake switch instead of the one that already on, Ill have to check if it is a 4 pin switch, guess ill have to get one from VX also.
4 pin brake switch is needed- best way is to pull the multiplug off your existing one to see what you have.
You may want to try a scappie for the brake switch but the clutch switch is rarer so probably a VX job. Try pposting on parts wanted.
Also be aware that the cruise actuator cable is different for the V6 and the 4 pot. Hope your actuator from ebay has the 4 pot cable because they are pricey from VX
Good luck
Oh Dear >:(
looks like a waste of money then. Guess Ill find out when it arrives and then ill have to get stung by VX if i want to go ahead and fit it
Yep The cable is pricey from VX £50 switches are £13.80 each
Hmmmm this could be Expensive Might just get a house brick and put it on the pedal :)
