Omega Help Area => Omega General Help => Topic started by: The Cambelt Kid on 12 August 2007, 13:38:00
Title: Quick MOT question...
Post by: The Cambelt Kid on 12 August 2007, 13:38:00
Hi Guys,
Is the electric mirror switch assy part of the MOT?  My switch assy is knackered and i can't move the mirrors...
Cheers
Marc
Title: Re: Quick MOT question...
Post by: Woodfull on 12 August 2007, 13:43:58
None of the MOT's I've ever witnessed have checked the mirrors for adjustment, so as I long as it's currently set up ok i guess you'll be alright.
If they do pick it up my feeling is it'll only be an advisory. :y
Post by: Darth Loo-knee on 12 August 2007, 14:16:58
Like already said never seen an MOT tester check that electric mirrors are working at all, they may say something if the mirror lense was smashed.
Post by: RobG on 12 August 2007, 14:43:29
Check this out. Relates to rear view and door mirror. Taken from updated MOT website  :y
a. missing or insecure
b. so damaged or deteriorated that the view to the rear is seriously impaired
c. does not provide a view to the rear of the vehicle
d. not clearly visible from the drivers seat, or incapable of being adjusted to be clearly visible from the drivers seat
http://www.motuk.co.uk/manual_810.htm
Post by: TheBoy on 12 August 2007, 17:29:07
They can generally be adjusted manually, so if the mirror isn't broken or dulled, it will be fine
Post by: lee4206 on 12 August 2007, 23:05:34
I'm a mot tester and it makes no difference if the switch is broken as long as the mirror is there and ok
Post by: The Cambelt Kid on 13 August 2007, 23:42:28
Thanks guys, that's put my mind at rest for now.  MOT due in 4 weeks and can do without small 'pain in the a**' issues before hand.
I think the only failure i did have was a rotten back box and centre boxes, which now been replaced with GM parts.  now she's running saweet!  :)
Cheers
M
