Omega Help Area => Omega General Help => Topic started by: STMO123 on 30 August 2007, 17:42:03
Title: Air flow meter.
Post by: STMO123 on 30 August 2007, 17:42:03
I am getting an intermittent EML, code 73, air flow meter. I am reluctant to part with any more hard-earned cash and I believe these little burgers are about £280. Is there anything I can do to service the existing MAF or are they usually just a replacement.
Cheers guys, Steve.
Title: Re: Air flow meter.
Post by: holey head on 30 August 2007, 18:01:38
apparently computer keyboard cleaning foam will clean sensor.
Post by: STMO123 on 30 August 2007, 18:04:36
Cheers. I am also getting a 135-----'Check engine' lamp (fault code lamp)---Low voltage. So, is the MAF at fault, or just the EML? :o
Post by: holey head on 30 August 2007, 18:11:02
just eml i believe. hope you sort car soon.
Post by: Golfbuddy on 30 August 2007, 18:53:18
Cheers guys, Steve.
Or £10 including postage for this one (http://cgi.ebay.co.uk/OMEGA-VECTRA-2-5-V6-MAF-SENSOR-PERFECT-WORKING-ORDER_W0QQitemZ200146914001QQihZ010QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem).  :y
And £45 for these (http://cgi.ebay.co.uk/Vauxhall-Air-Flow-Meter-Vectra-Omega-Frontera281002184_W0QQitemZ200145405415QQihZ010QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem).
Post by: cem_devecioglu on 30 August 2007, 18:56:00
Yep.
cleaning like this
http://www.popularmechanics.com/automotive/how_to/3297276.html
if fails
 buying second hand
Post by: STMO123 on 30 August 2007, 19:04:14
Yep.
cleaning like this
if fails
 buying second hand
 :y :y
Post by: STMO123 on 30 August 2007, 19:06:50
Cheers guys, Steve.
Cheers matey :y
Post by: Kevin Wood on 30 August 2007, 19:14:07
It'd be worth checking for any air leaks as well before condemning the sensor. Any induction leak downstream of the sensor (vac pipe / breather disconnected, plenum seal?) will cause its' reading to be called into question by the ECU.
Post by: old cruiser on 30 August 2007, 19:44:41
And also check the electrical connector pins on it for corrosion.
Post by: blue_dream on 30 August 2007, 20:03:20
Hi
     I too had this problem with the air flow meter, car would cut out for no reason and at speed, engine ran hot but not to boil, fault code pointed to meter.
  Checked all vac pipes for splits ,none and plenty of water in her, rad cap fine.
  Vauxhall quoted, wait for it   £320.00 !!! just for the part, had at look on ebay found a new one by Bosch though a car factor by the name of PARTSDOME 28, just put this name in their shops box NOW their price £68.50 + postage  !!!!! , JUST CHECK THE PART NUMBER ON THE OLD UNIT IS THE THE SAME AS THE NEW ON, their are two available for the 2.5 v6 and the 3 lite will not fit. ::)
Post by: TheBoy on 30 August 2007, 20:37:27
check for airleaks first.  if you have access to decent codereader that can do live data, use it...
Post by: STMO123 on 31 August 2007, 06:15:47
Stop talking bowlocks Jaime. :D You know very well that my 'live data codereader' is a piece of bent wire ;D
Post by: TheBoy on 31 August 2007, 10:33:38
before blowing £300 on new maf, worth getting indie to do a live data ?
Post by: STMO123 on 31 August 2007, 14:42:02
I've cleaned up the electrical connections and so far...so good :y
Thanks for your help chaps :-*
Post by: holey head on 31 August 2007, 17:17:53
your welcome bud, glad i could help!
