Omega Help Area => Omega General Help => Topic started by: Crazydad on 10 September 2007, 19:04:22
Title: Crank sensor
Post by: Crazydad on 10 September 2007, 19:04:22
Just a little question for someone who has no clue,
How long is the cable on the crank sensor normally,
 i have bought one and intend to fit tomorrow, just that the wire with the connector at the end of it seems to
be so short,any advice??
Title: Re: Crank sensor
Post by: VXL V6 on 10 September 2007, 19:28:40
Not very long, having a guess looking at the one in my boot I would say about 50cm
Post by: Crazydad on 10 September 2007, 19:43:40
Well that has now calmed me down thank you i thought that it would surely be longer as it needs to be run up the engine
Thanks for the reply :y :y
Post by: Crazydad on 10 September 2007, 19:44:35
have you got to do yours too then ??
Post by: Golfbuddy on 10 September 2007, 20:06:12
You got a little job to do tomorrow afternoon then Steve? Can't you get them to fit it at work for you?  :)
Post by: Baron Von Spongebob on 10 September 2007, 20:18:45
Hi Guys
Crazydad has asked me if you have more info on doing his crank sensor..I cant help him as not had experience with this but he will pick up the info tomorrow..
Any more pictures of top end connections would be appreciated.
Thanks for your help
Spongebob..
Russ.
Post by: Golfbuddy on 10 September 2007, 20:24:21
Hi Guys
Spongebob..
Russ.
Both of you, in here on the same day? That must be some kind of record. I didn't think you two knew the way into this area.  ;D ;D ;D
Post by: Baron Von Spongebob on 10 September 2007, 20:30:42
Hi Guys
Spongebob..
Russ.
Just askin on his behalf..  Too technical for me   ;D
Post by: Admin on 10 September 2007, 21:48:47
Well the crank sensor is quite an easy job.
Marks excellent guide is here: http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
And this is a picture of the crank sensor and its location.
(http://i16.photobucket.com/albums/b32/laidback66/IMG_0025.jpg)
Post by: TheBoy on 10 September 2007, 22:06:36
Well, that shows its plug anyway :P
The sensor is near oil filter.
Post by: VXL V6 on 10 September 2007, 22:32:20
Hello
Sorry for the delay, no haven't got to do mine but after a series of posts on here not so long ago where people were getting stranded because of the Crank Sensor failing I decided to keep a spare in the boot!!
Post by: Crazydad on 11 September 2007, 10:22:41
Sir Golfbuddy.........got to get used to that ;D ;D
It would be a damn site easier to get it done at work, and yes they would do it,we have 2 very good electricians here,
the only thing is i would like to do these "easy" things myself.
Call me silly if you want but after the rush i felt after doing the Fuel filter, i want to get it again........Silly eh?
Oh and by the way i have allready forgot how to get here again. ;D ;D ;D
Post by: Crazydad on 11 September 2007, 10:25:38
Laidback, Thanks a lot for the pic its nice to see the location of the plug, i had no idea what i was looking for :y
