Omega Help Area => Omega General Help => Topic started by: M-Tek Performance on 17 September 2007, 12:02:01
Hi,
If I wanted to put cruise control on a 2.5 TD, if i bought the correct stalk, what would I need to do to get it working?
Hi,
nothing, just the stalk. Job done.
Hi,
Wont VX need to turn it on??
plug and play but ive got the 2.2dti ;)
Hi,
Nope.
Every 2.5TD i have seen its just plug and play :)
Hi,
Nope.
cool.
just trying to weigh up pros and cons of a 2.5TD over an LPG converted MV6 / Elite!
TD's will be far more comon...
I know, but its a case of buying a TD or buying a V6 and having it converted.
the V6 will be around the £1k mark, plus another £1300 to convert.
the TD is probably around £1500.
Confirm it's plug & play but you will need a crosshead screwdriver to remove the lower steering-wheel nacele
The correct VX part is 9181012 (2 wire type)
IW
if you are after a facelift 2.5TD they are not the most common thing to get hold of
Most facelift diesels were 2.2DTi
Just an S reg.
All 2.5TDs have cruise enabled in ECU. This causes ECU to store an error if you don't have a stalk fitted - typical BMW!
