Omega Help Area => Omega General Help => Topic started by: jonathanh on 19 September 2007, 19:39:11
Title: Rear bumper removal
Post by: jonathanh on 19 September 2007, 19:39:11
Done a deal with the bosy shop that I'll drop the rear bumper off to keep the cost down when they fix the dent that the present other half put in the car last weekend.
Any tips on how to do it; I presume it is not too tough to do?  I could consult the Haynes book but that probably going to be as much use as it usually is....
Title: Re: Rear bumper removal
Post by: VX1 on 19 September 2007, 19:49:19
Rear bumper realy easy.
Each side of the wheel in the wheel arch are two screws undo these. From under the car (no need to raise) just under the bumper (wheel arch side) is another screw undo this. Once all six screw's are undone then at the rear of the bumper just under the boot striker plate is approx five screw's these are torx screw's undo these. Then under the bumper you will see three plastic clips, push the centre pin through and then pull the clip out. Once this has been don pull the bumper towards you and its off.
Hope this helps. By the way read the haynes manual it is correct. Done this on sunday to my car and took 5 mins to take off.
Cheers Paul  :y
Post by: IrmscherKris on 19 September 2007, 21:10:28
............when they fix the dent that the present other half put in the car last weekend.
Theres a lesson to be learnt here...  :y
Post by: jonathanh on 19 September 2007, 21:11:55
thanks mate, brilliant!
no need for me to worry about it
