Omega Help Area => Omega General Help => Topic started by: Don9247 on 03 October 2007, 18:14:36
i read the read up in what multirams are but how do i check they are working?
By blipping the throttle and watching the actuaters
I would be interested in this too.
I know the 2 multirams are supposed to open at different throttle inputs/engine speed, but how do you thoroughly test this - and if not working , where to from there?
Cheers,
Ian
BTW, how do you do that in a Facelift DBW?
I have having this problem too, i have checked mine, they are not opening, so what can i check from here???
Thanks, Mark. :y :y :y
Easy thing to check, the rear multi ram actuator should move around 1000 rpm, it is located under the four breather hoses on the back of the Plenum (the thing with ECOTEC on it)
(http://i155.photobucket.com/albums/s304/Loo-knee/RearMultiRamPicture.jpg)
The front actuator should move at around 4000 rpm, it is located at the front of the engine near the radiator
(http://i155.photobucket.com/albums/s304/Loo-knee/FrontMultiRamPicture.jpg)
Hope this helps :y
ok cool can see the front one kicking wheni rev it up but i cant see the rear one move at all. where can i get another can i swap the front to rear to double check?
I have noticed that my rear one moves momentarily if you give the throttle a sudden significant blip , but not if I open the throttle gently (although I haven't systematically tested around the 1000rpm level - not knowing that was significant).
I have just had a play with mine, the car that is, Ican get the front one to work at higher revs, but the rear one not moving at all, tried blipping it, opening throtle slowly, whacking it open and shut repeatedly, but to no avail....
Whats to check next?????
Thanks, Mark. :y
Dysfunctional multirams is normally poor vac system, so check for decent vacuum
How would I do this????
Also there is no heat in the cabin, gets just slightly warm, not blowing much either, could this be part of the problem, I only noticed this morning first time I have had to put the heater on.?
Thanks. :) :y :)
Check the vac pipe layout, as per M_DTM's guide in Maintence Guides
Hi, Sorry for being a bit of a tw@ but i cant find it, i have found this one http://www.omegaowners.com/forum/YaBB.pl?num=1153840176
but it dont show the vac layout, so I am assuming you are reffering to something else?
Thanks so far, im getting there, got the cruise working today :y
Click on this link, this is the diagram that you need to check the Vac pipes are in the right place :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
