		Omega Help Area => Omega General Help => Topic started by: volcanezx on 09 October 2007, 09:02:21
				Just bought an ex police MV6 estate, everything was fine fans came on shortly after 90 and cooled it down till about 87 or so. On sunday I was out and noticed the fans didn't come on when parked but made sure not to boil the car.  I bought the car for diffing and drifting can anyone tell me where the thermostate is so i can remove it and also how i can wire the fans up via a switch or get the fans to come on earlier. I've only done 200 miles in the car when i bought it i made sure there was no big pressure in the water bottle and there wasn't now however it seems that there is pressure in it can ANYONE HELP?????
				Here is
http://i181.photobucket.com/albums/x80/mecdv6/thermostat.jpg
dont use external switch ..it brings other problems
				I wouldn't remove the termostat either. That won't help and it's a nightmare to get to.
Sounds like you might have a dodgy fan switch, blown fuse in the engine bay fuse box or possibly a dodgy fan relay.
The cooling system should pressurise due to the expansion of the water, so that's OK.
				thanks just seems like such bad luck after so few miles and the car being a 2000. is the swicth the brass connection on the rad??
The fan temp switches are in the rad.
