Omega Help Area => Omega General Help => Topic started by: EddieX on 09 October 2007, 19:58:38
Title: EML slow to go out
Post by: EddieX on 09 October 2007, 19:58:38
Hi all,
Back from S. France, 2088 miles in 9 days   8-)
Biggest problem I had was the Wanli tyres on the back letting go in the wet on random occasions  :o
To the real question - For a couple of days, the EML stayed on for much longer than normal after starting. It seemed to cure itself but I was wondering if an overnight thunderstorm or parking beside a large communications tower would have caused it?
Any thoughts?
Eddie.
Title: Re: EML slow to go out
Post by: Entwood on 09 October 2007, 20:04:20
Probably nothing to do with this ..... but..
I had intermittent EML light for a few days in France after filling up with some cr*p fuel in the back of beyond... paperclip test got a code 44..my daughter checked the computer at home (usefull things mobile phones!!) and it said "mixture lean". We filled up with super unleaded at just above 1/2 a tank and the problem went away ... has not returned since.
Post by: cem_devecioglu on 09 October 2007, 20:11:16
Hi all,
Any thoughts?
Eddie.
Wanli...They are the worst in all tests..Better get rid of them..
also good idea to check ECU codes for problems ..Whats the mileage..
Post by: EddieX on 09 October 2007, 20:16:56
Hi all,
Any thoughts?
Eddie.
About 88000 miles.
I'm trying hard to wear those tyres out  ;) But they were new when I bought the car and I'm not too flush with money  :(
Post by: cem_devecioglu on 09 October 2007, 20:25:00
Hi all,
Any thoughts?
Eddie.
About 88000 miles.
Looking the mileage I can say Crank sensor is on the way to go(even without problem) , besides France  have a hotter climate this also can effect the sensor or ECU itself for adaptation.But in your case I dont see something criticial than your tires  :-/
Post by: TheBoy on 09 October 2007, 20:37:23
paperclip it and see what ecu has to say.
Post by: EddieX on 10 October 2007, 18:58:26
Tried that just now, it only flashed out 12 & 31 so nothing stored.
Car is running fine so no worries really, I was just curious about it.
Thanks,
Eddie.
P.S.
It had a new crank sensor 3 weeks ago for the same reasons that cem_d. mentioned.
Post by: TheBoy on 10 October 2007, 19:29:14
Thanks,
Eddie.
P.S.
In that case, check batt voltage, esp during cranking...
Post by: EddieX on 13 October 2007, 15:01:47
Now I've got the time AND it's daylight, I've checked cranking voltage. It's between 10.7 and 10.9 Volts. Thats OK isn't it?
Eddie.
Post by: Tony H on 13 October 2007, 15:38:11
Hi all,
Any thoughts?
Eddie.
About 88000 miles.
I bought my car with new Wanli's ftted o.k in the dry, but bl**dy lethel in the wet :o Got them changed under warrenty after a few weeks. The other downside with them is they last along time you could get over 20K out of them. That might be why there cr*p in the wet if the compound's too hard
Post by: cem_devecioglu on 13 October 2007, 20:11:11
Omega is heavy.Even in the dry with foot down on normal curves very easy to loose control with weak tires.
Before I had the same problem.. Good idea to stick to benchmark winners.
