Omega Help Area => Omega General Help => Topic started by: mjhayward on 14 October 2007, 18:42:34
Title: Main beam bulb
Post by: mjhayward on 14 October 2007, 18:42:34
Hi
I am new to the forum so HI just a quick question, how does the main beam bulb on a 98 2.5 CD release from the headlight unit? cant quite work out if it needs the three pins pushing down or what.
cheers
Title: Re: Main beam bulb
Post by: TheBoy on 14 October 2007, 19:11:56
Seem to recall, the top clips press together, and hinge on the lower clip.  Std H1/H7 type really IIRC
Post by: mjhayward on 14 October 2007, 20:33:51
Thanks, but the H7 seem to have no hinge clips only 3 tags for want of a better description, any ideas?
Post by: lee4206 on 14 October 2007, 21:43:39
Just changed a bulb on mine so i know this one. It is just held in by spring pressure if you pull it up it should pop out of the bottom springs and then come out easily and the new one just pushes back in.
Near impossible to just pull it out.
lee
Post by: mjhayward on 14 October 2007, 23:12:36
Thanks will give it a try in the morning.
