Omega Help Area => Omega General Help => Topic started by: madmax on 21 October 2007, 13:55:33
Title: heater problem
Post by: madmax on 21 October 2007, 13:55:33
recently replaced water pump and hbv and now only getting cold air coming through have done a thorough coolant flush as described in the maintence guide my question is could it be the new hbv as it wasnt  a vauxhall part and i remember reading that the non vaux hbv are not all that good..or is it just a bad airlock!!!!!!!!!!!!!!
Title: Re: heater problem
Post by: Jay w on 21 October 2007, 13:58:58
at the risk of sounding patronising have you checked all the vac hoses to make sure nothing has dislodged or broken/perished?
Post by: madmax on 21 October 2007, 14:05:28
yep checked  them seem fine but will double check to make sure!!!
Post by: Darth Loo-knee on 21 October 2007, 14:29:13
Make sure you have put the pipe back on top of the HBV, also follow that pipe it should go into the bulkhead. Paintshoptec had this with his car, where the pipe goes through the bulkhead there is a connection pipe apparently, his had come off. :y
Post by: madmax on 21 October 2007, 18:08:25
just finished messing about with car, i now have heat once more had a bad airlock squeezed large pipe next to battery a few times and out she come "the air  that is"
