Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 23 October 2007, 23:04:44
Title: Removing oil filter housing?
Post by: JamesV6CDX on 23 October 2007, 23:04:44
Hi Guys,
How does the entire oil filter housing come off, on later models? Looks like the whole housing has to come off, to reach the oil cooler pipe nuts...
Title: Re: Removing oil filter housing?
Post by: HI2DVY on 24 October 2007, 00:00:20
Remove the filter cover cap (24mm socket). This should only have been tightened to 15Nm so should come off easily - although be warned, they can sometimes be really tight and a nightmare to get off. Once the cover is off, the paper filter should come out with it. Inside the filter housing is a hollow bolt. This holds the housing to the block. Take this out and the jobs a goodun!  :y
Post by: Dazzler on 24 October 2007, 16:56:37
Sorted, spot on :y
