Omega Help Area => Omega General Help => Topic started by: Pitchfork on 29 December 2006, 19:25:13
Title: Adding Cruise control 2.5 TD
Post by: Pitchfork on 29 December 2006, 19:25:13
Previous cars (Mazda 626, Honda Accord & Volvo V70s) had this & after 3 yrs without I still miss it
Can it be retro-fitted to a '96 2.5 TD Estate (BMW engine)? If so how easy is it?
Regards
Ian
Title: Re: Adding Cruise control 2.5 TD
Post by: TheBoy on 29 December 2006, 19:29:55
Regards
Ian
Yup, plug and play on 25TD...  Fit the stalk and away you go :)
Note, the BMW 2.5TD takes a different cruise stalk to every other Omega - it needs to be the 2 wire cruise stalk...
Post by: Pitchfork on 29 December 2006, 19:33:31
Wow- what a fast response!
I don't suppose you know the VX part No. for the 2 wire version by any chance?
Ian
Post by: TheBoy on 29 December 2006, 19:37:50
Which engine code is it....
Post by: Pitchfork on 29 December 2006, 19:44:37
Don't know
How can you tell, what am I looking for & where?
Ian
Post by: TheBoy on 29 December 2006, 19:47:35
Probably X25TD or Y25TD...
Post by: TheBoy on 29 December 2006, 19:50:23
SWITCH, ASSY., TURN SIGNAL/DIM/DIP (IDENT BK) (FOR AUTO CRUISE CONTROL) U25TD, X25TD T1000001-  9181012 12 41 221 1
Note: RANGE: NO BREAKPOINT INFORMATION AVAILABLE
SWITCH, ASSY., TURN SIGNAL/DIM/DIP (IDENT BM) (FOR AUTO CRUISE CONTROL) X25TD  -11999999 9181014 12 41 224 1
SWITCH, ASSY., TURN SIGNAL/DIM/DIP (IDENT BM) Y25TD  -11999999 9181014 12 41 224 1
Note: FOR AUTO CRUISE CONTROL
SWITCH, ASSY., TURN SIGNAL/DIM/DIP (IDENT BK) Y25TD 21000001-  9181012 12 41 221 1
Post by: Pitchfork on 29 December 2006, 19:57:11
Have found the engine No.
30808544
Does this help to tell which engine type it is?
Ian
Post by: TheBoy on 29 December 2006, 20:41:31
Looks like chassis number is one you want, and you should be able to work out from above part nos... :)
Post by: tunnie on 29 December 2006, 21:18:20
Ian
Also check eBay for stalks, they can go cheap on there.
Double check which engine it comes from, as they don't always say.
I fitted a cruise stalk to a '95 TD Estate, just change the stalk and its job done  :y
Post by: TheBoy on 29 December 2006, 21:20:34
Ian
Problem with 2nd hand stalks, is that these stalks tend to fail as they wear, causing all sorts of probs, mainly with full beam coming on when not required...
Post by: tunnie on 29 December 2006, 21:22:56
Ian
True. Some people must just abuse them, that one i took of a scrapped Carlton CDX worked a treat  :)
Post by: TheBoy on 29 December 2006, 21:36:18
Ian
The extra weight of the cruise a stalk probably doesn't help....
And to quote Marks_DTM last time mine failed "It shows you use your indicators properly" ;) - apparently, the indicators wear a small slot in stalk, which cause the main beam to be on a hair trigger...
Post by: Pitchfork on 30 December 2006, 10:04:54
The Chassis No. is:
WOL000021V1063984
So can anyone tell me what version I've got please?
Ian
Post by: hotel21 on 30 December 2006, 10:43:51
You would need the engine number, not just the VIN.
If the last handfull of the VIN equals the engine number (most cars do) then looks like the first one....
The important bit seems to be T1000001- where the '-' means onwards.  The VIN does not reach the other end of the range where the next starts at X25TD  -11999999
Just reread....  Now I'm as confused as you!  It appears that your VIN will fit between both...   ::)
NEXT LUCKY ENTRANT PLEASE!!    ;D
Post by: Pitchfork on 30 December 2006, 18:53:08
Car first Registered Oct 96
Does this help with identifying what engine I have & which Cruise Control stalk I need??
Surely someone must know!
Ian
Post by: Pitchfork on 06 January 2007, 16:59:10
UPDATE
Well, I went to local VX dealer in Basingstoke who assured me that there was only a single cruise control part for the 2.5TD (Part 9181012) & that I an XD motor so.....
I bought a used control on e-bay, fitted it & it works beautifully (only a couple of minutes to fit if you ignore Haynes' instruction to remove the Steering Wheel).
Now I know that some of you deride what you call 'Tractors', but I'm impressed by the fact that, as was mentioned by another member, adding Cruise was as simple as 'Plug & Play'
Got me to thinking, are there any other similar updates for this model, where the features are already programmed in the ECU, & only require the appropriate component to enable them?
I'm keen to improve the fuel consumption, is there an add-on or a recommeded chip upgrade intended to do this rather than turn the car into a F1 contender?
Ian
Post by: TheBoy on 06 January 2007, 17:48:38
UPDATE
Ian
Sorry, I'm a big culprit for referring to that diesel engine as a tractor engine  :-[
Glad you got the cruise going - it is really easy on that model :)
Quite a few upgrades possible using ebay bits to the car, not much for engine though.  They can be chipped to good effect (Omega 2.5TD is heavily detuned), one of your fellow tractor owners will no doubt advise in that department (apparently OmegaToy's TD goes like a rocket with a chip and another 'secret' mod).
HTH
Post by: wozzle71 on 06 January 2007, 17:50:32
scuse me for sounding numb ive got an auto 2.5 td cd '97 am i right in my understanding that all i have to do is buy a new stalk attatch it to the steering column and i will have cruise con?
Post by: Andy B on 06 January 2007, 17:54:27
Sorry, I'm a big culprit for referring to that diesel engine as a tractor engine  :-[ ...
Or diseasal.  ;D  ::)
Post by: TheBoy on 06 January 2007, 17:58:47
Yup.  Has to be the diesel cruise stalk as different to more common petrol one. Also, if manual g/box, you need a clutch switch as well :)
Post by: TheBoy on 06 January 2007, 17:59:57
Or diseasal.  ;D  ::)
LOL.
I'm actually a diesel fan, just not that impressed with the one in the Omega (or same engine in Landrover, or in BMW)
Post by: tunnie on 06 January 2007, 18:00:35
Yep £30 and you got cruise  ;) :D
Post by: TheBoy on 06 January 2007, 18:01:34
if autobox, else £40 ish (+VAT)
Post by: wozzle71 on 06 January 2007, 18:02:11
cheers for that now on the lookout for diesel stalk car has auto box so hopefully be even lazier soon ;)
Post by: tunnie on 06 January 2007, 18:04:21
A Vauxhall Dealer would be the best place... they are a good price around £30 ish... 2nd hand ones can be dodgy.
Post by: wozzle71 on 06 January 2007, 18:05:12
is the 30pound new or from e bay
Post by: TheBoy on 06 January 2007, 18:07:34
Petrol ones £30 + VAT from dealer. I assume diesel about the same...
I would be wary of second hand ones...
Post by: wozzle71 on 06 January 2007, 18:15:34
thanx for that,just been told about a chip on ebay to boost mine from 143 to 177bhp approx. is it worth doing on a 97 2.5 td with 159000 on the clock ?
Post by: tunnie on 06 January 2007, 18:17:00
omegatoy chipped his, and its very quick.
If its a manual, yes chip it. Auto's... ermm personally i wouldn't. The autobox would not handle the extra torque for long....
Post by: Pitchfork on 06 January 2007, 18:37:07
New Cruise control is £37 +VAT
I have an Auto so it's as simple as swapping the indicator stalk. Just make sure you get part 981012
Even if the used one that I got on e-bay fails, it's cheap enough to replace (I wonder why it was never standard?)
Now - how about mods to make it more economic  on fuel? I don't need that extra Horse Power!
Ian
Post by: wozzle71 on 06 January 2007, 18:54:51
wot even though the box is a bmw one
Post by: tunnie on 06 January 2007, 19:06:27
The autobox is not BMW, only the engine is  :y
The autobox in the diesels is not the strongest even with standard power... although post '98 i belive it was fitted with a better box (AR35?) Not sure...
Post by: TheBoy on 06 January 2007, 22:52:26
Yes, the g/box is a GM unit. Earlier ones had the AR25, not really strong enough, and usually end up failing. Later ones had the AR35 as fitted to 3.0/3.2 petrol, much stronger.
I do not know when the cutover was from AR25 to AR35...
Post by: kbou55 on 03 July 2007, 20:15:54
The Diesel is a drive by wire system (no throttle cable) so its the engine ecu that controls the diesel pump electronicaly.
It uses a BMW management unit, this uses a set of resistors to signal which button is being pressed on the cruise stalk and hence the stalk is different to a standard Vauxhall one (and why there is only 2 wires).
2.0/2.2 Diesels use the same stalk as petrol models.
I found this out to my dismay  :'( when i bought a cruise control stalk from fleabay that would fit "all omegas" >:( >:( >:(, lying b!!!ard.
Post by: TheBoy on 03 July 2007, 20:17:56
Yes, 2.5TD uses the unique 2 wire stalk (£30 ish from dealer), all other Omegas use 4 wire stalk.  Due to the cheap price new, and the high failure rate as they get older, its false economy to buy 2nd hand...
Post by: Pitchfork on 04 July 2007, 07:47:14
Fitting will take no more than 5 minutes
I bought one on e-bay for £5 & it has given no problems
Cynically, I suspect that not fitting it as 'Standard' meant that dealers could charge £100's extra for the feature when the car was ordered new
IW
Post by: TheBoy on 04 July 2007, 08:16:39
IW
Keep an eye on full beam coming on or flashing unexpectedly...
I think they did it to keep model range consistent. Remember, the non dbw petrols needed actuators etc which were costly, so only fitted to cdx and elites...
Post by: kbou55 on 24 October 2007, 14:37:43
if your not sure which cruise control stalk to get, take off the cowling behind the steering wheel and fish out the plug , it will be on the left hand side.
if its 2 wire, you need cruise stalk part number 9181012       12 41 221 1        (IDENT BK)
my tech jockey in the opel garage said this is the ONLY one for the tractor.
FYI, the cruise control stalk for the BMW TD is resistor operated instead of switch based for all other omegas, i whipped out my digital multimeter (calibrated) and got the following values. all vales are in ohms.
nothing pressed       670[ch937]
0 pressed              1680[ch937]
I pressed               61.2[ch937]
R pressed            155.3[ch937]
info may be usefull to someone.
Post by: TheBoy on 24 October 2007, 20:14:34
For Omegas, the 2.5TD takes the 2 wire variant (with the resistor network), and all others take the 4 wire type...
