		Omega Help Area => Omega General Help => Topic started by: retro_al on 30 October 2007, 16:09:03
				Do they work then? im sick of my missfire and thought if i buy one of them (if they have a vauxhall one) it will tell me the problem :( :question
				What engine and do you have a fault light on?
				what fault finding thingy is this ? Haynes Manual ?
You will have better luck asking questions on here for fault finding
				If it's the Gunsons one it's just a switch and two lengths of wire..... A paperclip will work just as well (depending on your engine!)
				its a 2.5 v6 changed the ign leads put a new crank sensor on and its still playing up :(
				http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
Have a read through of this
				ah thank you, very helpfull  :D
				If you have changed the rpm senor and the ht leads then the missfire is most likley to be the dis pack behind the passenger side head. :(
See what fault codes say first ;)
I agree though, no fault codes and a misfire normally point HT. Worth checking for oil in plug wells first ;)
