Omega Help Area => Omega General Help => Topic started by: Missy_MV6 on 10 November 2007, 19:49:59
Title: Advice Needed... Climate Control
Post by: Missy_MV6 on 10 November 2007, 19:49:59
Hi Guys
Well....it had to be done we have just gone and bought ourselves another Omega MV6  8-) So have 2 sat on the drive at the mo  :y
But unlike our old one this has full leather and only 54,000 with full service history :o
My hubby drove it back and noticed that when he put the Dual Climate Control on  the "Hi" setting it blew hot he then moved it down to number 27 and it blew quite cold on our old Omega it wouldn't blow cold until it was down about 22 and below.Surley it should blow warm at about 24/25 ?
Any suggestions ?
Title: Re: Advice Needed... Climate Control
Post by: JamesV6CDX on 10 November 2007, 20:02:00
Is the sampling fan working properly?
Post by: Darth Loo-knee on 10 November 2007, 20:17:51
I don't know for sure so I maybe wrong, but I think it depends on the temperature in the car as to how much cold the climate puts in...... for instance when i am in the car I have it on HI, when my mrs gets in i turn it down to 26-27, and because it is boiling in there it puts cold air into the car to cool it to 26-27...
Hope that makes sense ::)
Post by: Missy_MV6 on 10 November 2007, 20:18:31
Hi James
What is the sampling fan and where is it located and how would I know if its working/not working?
Thanks
Post by: JamesV6CDX on 10 November 2007, 20:20:34
Sampling fan is behind the climate panel - it blows cabin air onto a sensor, which in turn senses the temperature of the air, so it knows how much to cool/heat the cabin dependant on temp selected.
If this isn't working, it won't sense the right temp, and won't operate properly.
Post by: Missy_MV6 on 10 November 2007, 20:21:20
Hi James
Thanks
Well maybe thats so...My hubby did have the car ticking over whilst inspecting the car and then he did take it out for a spin and then it was a 90min drive back in some heavy traffic.
Cheers for that ;)
Post by: JamesV6CDX on 10 November 2007, 20:22:58
Hi James
Thanks
Cheers for that ;)
If ever you're down near Nottingham, talk nicely to Mark and see if you can get a Climate software upgrade :)
Btw, nice avatar!
Post by: Missy_MV6 on 10 November 2007, 20:23:16
Is there a test for this to find out if it's actually working ?
Post by: JamesV6CDX on 10 November 2007, 20:24:13
You may be able to hear it working... but I'm not really sure, may need to pop the panel off to make sure it works
Post by: Missy_MV6 on 10 November 2007, 20:29:14
Okay my hubby will have a play tomorrow...Thanks for the help  ;)
Post by: Entwood on 10 November 2007, 20:30:00
IIRC the sampling fan is behind the little grill in the centre of the climate control panel .. place a small piece of tissue paper close to the grill ... if it is sucked towards the grill the fan is working, if it falls away the fan is not working...
I think thats the right way  :(
Post by: Missy_MV6 on 10 November 2007, 21:02:30
Ok will test it tomorrow thanks  :y
Post by: GastronomicKleptomaniac on 10 November 2007, 21:16:12
Hi James
Thanks
Cheers for that ;)
Btw, nice avatar!
 Climate software upgrade? Whassat then? :D
Post by: STMO123 on 10 November 2007, 21:26:56
Fan may be OK. Sensor may be duff.
Post by: TheBoy on 10 November 2007, 21:52:09
As well as the fan working, ensure the sensor is not touching anything (have to dismantle to check).
Is it a facelift, or prefacelift?
Post by: Mike Collins on 10 November 2007, 21:57:32
Hod on, you set to 27?, the interior is trying to cook itself so lots of hot air and interior temperature rising. Then you set it to 22, it now has to cool the interior, cold air from the vents until the interior temperature drops. Small steps and see if it settles.
Post by: Missy_MV6 on 10 November 2007, 22:28:49
It's a pre-facelift  :)
Post by: Missy_MV6 on 10 November 2007, 22:30:58
Initially he set the temp to "Hi" and then after a bit he wanted to just have the cabin warm and so dropped it to 27 and it started to blow cold rather than the warm air he thought it would.
He thought it shouldn't blow cold air until it was down to around 22
Post by: VXL V6 on 10 November 2007, 22:39:21
It'll do whatever is necessary to get the cabin to the temp you select, be that blow cold air or hot.... however low will just blow cold air continuously and high will blow hot air continuously.
Post by: TheBoy on 10 November 2007, 22:59:28
prefacelift mv6 (being either a 98 or 99 year) does not benefit from a climate upgrade
Post by: Boldy on 11 November 2007, 09:48:48
Dont want to start a new topic so ill ask here:
1) Does 2002 Omega 2,5 DTI will benefit from c/c upgrade?
2) Same about engine and gear box ECU (it has 5 speed auto gear box)
Post by: Missy_MV6 on 11 November 2007, 14:36:20
Thanks for all the info guys.......A friend of ours told us to reset the controls and hey presto we went out in the car today and the climate is working fine...Cheers for all the help  ;)
Post by: TheBoy on 11 November 2007, 16:33:29
1) Yes
2) Not sure, we didn't get the 5 speed box here, so never done one.
Post by: davlad22 on 12 November 2007, 02:21:34
I find the climate control on the facelifts really queer, without the 'upgrade', if changing temp the system tries to alter the climate as fast as it can so perhaps would result in cold air being blown to equalise! I do gather the revised software makes the system more 'discreet' which can only be a good thing!
Boldy, I think Mr DTM maybe a little too far away from you, I suppose see what the local dealership say, unless of course you are arranging a 'tech 2 holiday' :)
Post by: Marks DTM Calib on 12 November 2007, 08:23:12
I fixed the faulty fan on my (pre-facelift) climate at the weekend using a 1inch 12V computer fan.....it now works very well.
