Omega Help Area => Omega General Help => Topic started by: jimtoon on 20 November 2007, 17:10:57
Title: Omega 2002 2.2CD auto "water?" on the drive
Post by: jimtoon on 20 November 2007, 17:10:57
Had this lovely car for a week
After a very short trip 8 miles have a pool of "water" Local "vauxhall main dealers" assure me it is normal from the a/c
Can anyone confirm this? and then I can sleep soundly!
Title: Re: Omega 2002 2.2CD auto
Post by: Grumpy on 20 November 2007, 17:25:04
Hi, Jimtoon, and welcome.
A pool of water is never normal.
Did they sell you the car?
Where is this pool?
Inside the car or under the engine?
Inside is probably a blocked scuttle drain.
If coolant, then a leaking heater matrix.
Outside, under the engine, will either be a coolant leak
or a washer bottle leak or washer pipe off.
Are you losing either coolant or washer fluid?
Post by: Entwood on 20 November 2007, 17:25:27
It is common for water to drip from the air-con ... the plumbing gets cold and water condenses on it, as well as being extracted by the drying process...
How much water depends on many things ... Air temperature/humidity.. what settings you have inside the car...  how long its been running etc etc. This time of year I would not expect a "puddle" after just 8 miles !!
All I can suggest to you is .. as long as the level in the coolant bottle is not changing, you don't have a problem with a coolant leak !! The only other source of water is the screenwash bottle ... so if the level there is constant whilst not being used .. I would guess it could be the aircon....
The last point to look at is the near side scuttle drain ... with all the rain we've had that might only be draining slowly ... it MUST drain properly or problems will result !!
HTH
edited for smelling pistakes ... and SNAP to grumpy !!  :)
Post by: arthill on 20 November 2007, 17:26:09
Hi and welcome
 can you give more info. ie. location of water etc. and possibly get comments from others with experience of similar prob.
   John
Title: Re: Omega 2002 2.2CD auto "water?" on the drive
Post by: Marks DTM Calib on 20 November 2007, 17:28:16
If the pool of water is clear and just behind where the gearbox bell housing is then its aircon condensate.
Post by: jimtoon on 20 November 2007, 17:34:42
Thanks to all of you!
The water is below the front offside of the engine
It has the consistancy of distilled water
The coolant level is constant after a 240 mile trip home
Post by: Marks DTM Calib on 20 November 2007, 17:37:17
Petrol or diesel 2.2?
Post by: jimtoon on 20 November 2007, 17:40:51
petrol
Post by: Marks DTM Calib on 20 November 2007, 17:44:29
In front or behind the OSF wheel?
Post by: arthill on 20 November 2007, 17:45:57
check if any leaks coming from water pump thats in that location.
  John
Post by: Marks DTM Calib on 20 November 2007, 17:47:26
Also, what colour is the water in the header tank?
Post by: jimtoon on 20 November 2007, 17:56:38
Thanks John
Mark    colour is pinkish but pool is clear and behind the OFS wheel
Post by: Grumpy on 20 November 2007, 19:31:28
I must be having a senior moment. I can't recall seeing the "water on the drive"
bit in the thread header. That's why I asked where the 'pool' was.
Exactly how big is this pool?
If your coolant level is ok, and assuming it isn't just a small air con drain puddle,
then you're looking at either a washer leak or a blocked drain that is collecting
rainwater and dumping it.
Check your washer bottle level. Top up and operate your washers. If you have
headlamp washers, then I believe that you'll need to have your headlights on to operate
and check these. I'm not positive on this last bit, as I only drive the 'Cheap Seat',
but someone here will give the real gen.
Edit:
Forgot to add this bit.
What you're looking for here is the washer pipework split or disconnected. A split or
disconnected pipe can jet water into all sorts of strange places.
Post by: jimtoon on 21 November 2007, 10:13:38
Thanks again for all the advice
Will inform of any"results" :y
Post by: Andy B on 21 November 2007, 10:40:04
Taste it!!!!
If it tastes sweet it'll be coolant, if it tastes soapy it'll be washer fluid. Condensate & rain water don't taste of anything much!!
Post by: Jimbob on 21 November 2007, 10:42:56
could always dunk some white kitchen towel in it, should show the colour
Post by: hotel21 on 21 November 2007, 11:20:01
Before tasting it, just check that next doors cat/dog/whatever has not been hiding under there and left a little 'present'.... :o
Post by: Andy B on 21 November 2007, 11:25:35
 ;D  ;D When I say 'taste' ..... I mean to dip your finger in to test. Not a cup full!  :y
Post by: jimtoon on 21 November 2007, 15:23:38
Solved!!
Had cam belt changed this PM and they found the a/c drain channel blocked  only allowing some water to escape
On clearing trapped water gushed out and all seems well(dangerous to say this but have faith!!! )
Interesting though and NO water on the drive
Thanks All
