		Omega Help Area => Omega General Help => Topic started by: bogit on 25 November 2007, 08:52:57
				Speedo's staying at 0 whan moveing, but moves slightly on ignition on and off. tc and abs lights on.
 miles and trip in the speedo still turning.
 trip/ avridge speed on mid stuck at 0 after reset on the stalk.
 still the old faithfull mv6 3ltr auto minface lift.
 any ideas ?
 (tc definatly not woring,havent had to test the abs yet :)     )
 any ideas ?
 ABS ECU fubar'd :( Well documented for your(our :-/) year of car.
				I would second that. Fiddly job. Do a search on ABS ECU in general forum. There is also a comprehensive guide in the maintenance section.
 Other symptons are no cruise control and sometimes heavy steering.
 Can you put some details of car in your profile please? It helps with answers to questions.
 If you decide to change it I have some photos of tools that are useful and the unit when it comes off which I could Email you.
 varche
				Have exactly same problem with a 1998 2.5V6 Elite Estate auto - see the following post for info - http://www.omegaowners.com/forum/YaBB.pl?num=1195514364
 Hope this is of help.
				Yep, replace/repair ABS ECU about £125 for a recon unit.
				abs failure, fairly common on post 98 models.
				Its that common that I keep asking for a broken ECU to disect and to date......I have not got one.
				Its that common that I keep asking for a broken ECU to disect and to date......I have not got one. i think most peeps are using a refurbishment place...  :'(
				Given the cost of re-furb, the failure can be little more than a dry joint or faulty relay.....cant be to hard to repair and would make a great maintenance guide.
 My thoughts exactly...
 I know on a members P reg (so before the troublesome type), I bodged a failing abs by tapping the relays...
