Omega Help Area => Omega General Help => Topic started by: Jimbob on 07 December 2007, 10:07:03
Title: 2.2 Sounds like a tractor :(
Post by: Jimbob on 07 December 2007, 10:07:03
Just had a call from a stranded Mrs Jimbob  :(
100 yards from school, car on accerlation the car started jumping, no engine lights.
drops the little fella off, gets back in,
restart it to leave, car is jumping / shaking, sounds like a tractor
Engine management light lit, and Auto Gearbox check.
She turns off at this point and calls me.
I start it up, engine sounds sweet as a nut, but is vibrating quite a bit.
EML still on, Check gearbox still on.
I drive it home slowly like a manual.
Get the cheapo tech2 and have and old P1613 (immob) and a new P0353 - Ignition Coil 3 Incorrect Signal
Couldnt read gearbox :(
Gearbox was clunky to change, initial thought thrust washer?  or is this maybe a red herring.
Help  :(
Where should I start, check the spark plugs?
Title: Re: 2.2 Sounds like a tractor :(
Post by: Marks DTM Calib on 07 December 2007, 10:08:03
Pop the coil pack out and check for water......
Post by: Jimbob on 07 December 2007, 10:13:02
Will do, we did have an awful lot of rain here yesterday
Post by: Jimbob on 07 December 2007, 10:23:04
1 Moral to this story.....get a code reader BEFORE you need a code reader  :y
Post by: Jimbob on 07 December 2007, 11:52:41
Correctly Diagnosed as per usual  :y
Plug 3, damp
Plug 4, Swimming
So now what?
Ive tried the wells as best I can with kitchen towel, and dried cpp pack.
Should I dry more thoroughly with hair dryer?
should I put cpp pack back on and see what happens?
or am I likely to need new cpp / plugs?
Cheers
Post by: Matchless on 07 December 2007, 11:57:58
That should be enough to get it running properly but it could do with a decent run to thoroughly heat the head etc to drive off any remaining dampness or the missfire might return at the next cold start.
Where did the water come from? scuttle / wiper holes? Can you stop it happening again?
Post by: Jimbob on 07 December 2007, 12:01:01
A good question, cant see any water traces anywhere  >:(
We did have hours of torrential rain last night (some of which the car was driven in)
Post by: Marks DTM Calib on 07 December 2007, 12:01:08
Now put some sealent around the rubber that the wiper arm studs stick through on the scuttle.
Post by: Jimbob on 07 December 2007, 12:02:10
we talking silicone or grease?
Post by: Marks DTM Calib on 07 December 2007, 12:03:17
Silicon (sikaflex is good) your looking to seal the rubber part to the scuttle moulding
Post by: Jimbob on 07 December 2007, 12:03:58
That I can do  :y
Post by: Matchless on 07 December 2007, 12:05:54
In a past life I used to use french chalk or talc to track the path of any water leak, if you have access to a puffer pack of Johnsons baby powder then try to get a thin dusting around and under the scuttle. any water drips clean off the powder so you can see where it started from.
Post by: Jimbob on 07 December 2007, 12:06:33
I've 2 young kids so no probs  :y
Post by: tunnie on 07 December 2007, 12:33:02
Jimbob drop AA a PM he had the exact same problem, he seal the base of his wiper blades with a special silcone thingy.
Seams to affect later facelifts, both mine and my dads have never had problem with water in the plugs.
Post by: Jimbob on 07 December 2007, 12:34:44
Interesting, although think our is earlier than both yours?  2000?
Post by: tunnie on 07 December 2007, 12:39:15
Mines a 2000 on an X, dads is 2001 on a Y.
Dads one was never garged until recently, think mine was by its previous owner but generally mine was left outside too.
Did the HG on my dads 2.2, the plugs where bone dry.
Also mine *touch wood* has never done it either, and my scuttle is far from perfect nick...
Post by: Jimbob on 07 December 2007, 12:40:54
OK, this is a W.
Gonna put it back together in a bit, if it runs ok, I'll send her off for a drive.
New battery to go on, and Wipers to seal tonight.
Will also check the airfilter is nice and dry  :y
Post by: Jimbob on 07 December 2007, 12:43:20
Is it worth spraying anything with WD40 before it goes back together?
Post by: tunnie on 07 December 2007, 12:57:00
When doing the Senny plugs, we put bit of wd40 on the plugs. Forget the reason why, think its cleans them up?
It smoked like a train for few miles but cleared up.
Post by: Jimbob on 07 December 2007, 14:00:27
Was dryish, gave it a spray of wd40
Started and sounded perfect...
So off we went
2 miles or so, perfect, then EML :(
The jumping and farting
then Check Gearbox.
limped home, and taken apart again.
Think we have found the fault, just more thorough drying required.
Post by: Kevin Wood on 07 December 2007, 14:17:35
Sounds like there's still water lying around, everything's fine until the engine gets up to temperature, then the water starts to vapourise and at that point it gets to places it shouldn't be and the misfire returns.
Post by: Jimbob on 07 December 2007, 14:20:36
I think your right, hairdryer at the ready  ;D
Post by: Taxi_Driver on 07 December 2007, 14:23:12
Doesnt seem to effect mine.......but maybe, vx modified it by then?  :-/
Post by: Jimbob on 07 December 2007, 16:19:57
Had another look (now ive finished work  ;D)
Wells still wet, drive obviously disturbed water.
Dried em out using a cut of piece of sythentic chamois, pushed in with a screwdriver  :y
CPP unit in a warm place, facing downwards.
All drying nicely, will test again tomorrow.
Found where the water is coming in....
The scuttle is in 2 pieces, where one bit overlaps as it drains into pollen filter area, water is tricking underneath and onto main breather pipe area.  Just need to dry and try to seal that as well.
Here's hoping that lot will fix it  :y
Post by: tunnie on 07 December 2007, 16:42:12
Jimbob, try cranking the engine with the coil plug assembly off, that should move things around without the need to re-assemble and drive.
Post by: Auto Addict on 09 December 2007, 08:26:47
I've had this problem, it's the rubber seal at the bottom of the windscreen, it needs removing and sealing properly.
Post by: Jimbob on 09 December 2007, 21:07:39
Found the leak, just need to seal it
All dryed out, did 40 odd miles today, couldnt get an EML however hard I drove it, So looks to be fixed  :D
Just the leak to sort at some point soon.
Rechecked codes, and developed a P1403 whatever that is, but running fine  :y
Thanks All!
Post by: Marks DTM Calib on 10 December 2007, 08:42:24
Very good...... P1403 is not a recognised code......
Post by: Marks DTM Calib on 10 December 2007, 09:07:44
Added a list of the 2.2 fault codes to the FAQ area.
Post by: Jimbob on 10 December 2007, 09:44:08
Thats the 2nd unrecognised code the cheap has given me  :-?
Hows your software mods coming along ;)...If you need a tester just let me know  ;D
