Omega Help Area => Omega General Help => Topic started by: Varche on 16 December 2007, 12:12:54
Title: Paperclip test  code 16
Post by: Varche on 16 December 2007, 12:12:54
A few weeks back I did paperclip test, posted results and thought I had cured it with a different Throttle position sensor.
had a least 20 clean starts so any stored codes should have gone from that problem.
Yesterday the EMl came on and stayed for about five mins before staying off since.
The code is 16 . Any suggestions or ideas welcomed?
varche
Title: Re: Paperclip test  code 16
Post by: Bandit127 on 16 December 2007, 13:09:03
There's a post just above yours (until I post this..) with the same error. For general reference, Mark's list of codes for the V6 is in the FAQ section.
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
Jim
Post by: TheBoy on 16 December 2007, 14:37:01
knock sensor, check for trapped lead....
Post by: Marks DTM Calib on 16 December 2007, 18:59:50
Knock sensor number 1....which is the air filter side....
Check for trapped wires or a poorly routed wire which is being caught by the aux belt.
