Omega Help Area => Omega General Help => Topic started by: steve121 on 30 December 2007, 11:33:05
Title: facelift crse control
Post by: steve121 on 30 December 2007, 11:33:05
hi all, can anyone please tell me if i need any other bits to put crse control
on my w reg 2.5 cd v6 petrol apart from the stalk ::) many thanks.
Title: Re: facelift crse control
Post by: alexandjen on 30 December 2007, 11:41:46
Have a look at this how to.....
http://www.omegaowners.com/forum/YaBB.pl?num=1197646817
Post by: tunnie on 30 December 2007, 11:52:26
because its a 2.5 and not the later drive by wire engine, you need all the extra gubbins to make it work! not just a stalk
Post by: steve121 on 30 December 2007, 12:18:31
thanks tunnie, i thought that would be the case. :(
Post by: tunnie on 30 December 2007, 12:22:47
Its still a straight forward job, and could still cost less than doing it on a later engine, as no tech2 is required.
Keep an eye out for Elites/CDX's being broken on eBay for cruise bits  :y
Post by: Bourne on 31 December 2007, 16:23:36
Just done this on my 98 mini facelift MV6.Although straight forward , be prepared for the fact that changing the brake switch can be awkward because of where its located (especially if you've got big hands).Very worthwhie mod though.
Post by: davlad22 on 31 December 2007, 16:29:24
Will the parts from a similar aged Vectra fit then??? It's certainly worth the 50 quid most sellers want for the parts I would say!  :y
Post by: harryomega on 01 January 2008, 22:59:57
hi, i fitted cruise to my 2.5 td works fine, all you need is to replace indicater stalk and you away.
Post by: harryomega on 01 January 2008, 23:00:56
forgot to add mine is an auto.
Post by: davlad22 on 02 January 2008, 02:54:19
Yours is a BMW diesel as well, completely different!
Steve, you need the full kit, stalk, cable, ecu etc  :y
Post by: tunnie on 02 January 2008, 11:14:28
what he said
harryomega > i was refering to the 2.5 V6 petrol, not the 2.5 BMW diesel.
You are correct though, the 2.5 diesel is just a new stalk, job done.
Petrols though need more work!
Post by: MickAP on 02 January 2008, 11:19:08
Hi
Will I need just the stalk on mine, or the full kit.
Year 2000 2.5TD manual.
Mick
Post by: Marks DTM Calib on 02 January 2008, 11:24:11
Just the stalk but.....the 2.5TD uses a special stalk which is different to the petrol models.
Post by: tunnie on 02 January 2008, 11:49:10
Mick, you may need a clutch switch, with yours being a manual... however i fitted a cruise stalk to Omegatoys 2.5 TD manual and it worked straight away.
Post by: TheBoy on 02 January 2008, 20:31:06
clutch switch already fitted on TD
