Omega Help Area => Omega General Help => Topic started by: irratic on 30 December 2007, 12:28:06
Title: serious braking problem
Post by: irratic on 30 December 2007, 12:28:06
my mate has a 2.5 estate. always run fine. a couple of weeks ago when you brake the car pulled to the left then the right then back to the left and so on.. as if you were on ice.its reached a stage where it is seriously dangerous to drive.. the problem is i cant find the cause. wishbones were fitted less than 12 months ago. can't find any play or movement in them.. so fitted new front discs and pads, callipers are free enough..that has made no difference at all.checked track rod ends, replace the steering idle arm (v,slight wear) has made no difference.thought it could be ABS problem. pulled the fuse has made no difference..does pulling the fuse stop the ABS working completely??? could this be a faulty ABS ecu and valve block??? i will try anything, i am completely out of ideas now... any suggestions are welcome. ( and yes a gallon of petrol and a match has crossed our minds) thanks
Title: Re: serious braking problem
Post by: Kevin Wood on 30 December 2007, 12:44:29
Might be worth checking the rear suspension for any play, etc. Sounds to me like something's giving a little under braking load.
I assume the geometry was setup correctly after the replacement of the suspension components and that tryes are OK and at the correct pressure?
I doubt ABS is involved as it only affects braking once the brakes have started to lock. Might be worth taking it to an MOT station and asking them to check the brake balance left/right on the follers, front and rear. You could also try temporarily removing the ABS fuse (19 IIRC) but I doubt it'll make any difference. My money is on some play somewhere.
Post by: JamesV6CDX on 30 December 2007, 12:46:50
Jack up each corner at a time, and rock the wheels, feeling for play
Post by: motmann on 30 December 2007, 12:50:27
did you check front springs, drop links,anti roll bar? has the car been kerbed and your mate not mentioned it?? directional tyres? tracking on omegas can be quite critical, i have always had mine set more or less 0toe in/toe out if not they knock the front tyres out pretty quick!!  have another look maybe?
Post by: irratic on 30 December 2007, 12:51:31
jacked everything up and shook the wheels. had a bar on the wishbones, no play anywhere that i can find. thats why i thought it could be abs valve problem.......its definately a front end problem,
Post by: Darth Loo-knee on 30 December 2007, 12:51:53
I had the exact same problem a few weeks back, it did turn out to be the wishbones.. I couldn't see myself until i got it over a pit, I waggled the steering wheel my mate underneath watching, the whole wishbone on the passenger side was moving backwards and forwards. While I was waiting for the wishbones to arrive i carried on driving the car which I would never do again.... I think it must have made the drivers side worse and i felt like the car was skating all over the road scared me being honest.
Post by: JamesV6CDX on 30 December 2007, 12:53:47
when the wishbones were fitted, were they torqued up with the car on the ground?
Post by: irratic on 30 December 2007, 13:15:54
did the car feel you like you were on black ice when you braked???? i'm prepared to change the wishbones again if that would be the problem. and yes i replaced the wishbones last time so they were torqued up wile the car was level.
Post by: motmann on 30 December 2007, 13:16:05
mite be difficult to answer this one but when the wishbones were replaced were thay genuine vauxhall ones or bandit?? the cheaper ones dont seem to last as long....
Post by: irratic on 30 December 2007, 13:19:20
they were ones from the local motor factor, so they were copies i assume.
Post by: davlad22 on 30 December 2007, 16:55:18
Steering rack? Track rod ends? Nobody really knows without seeing it. Hope you manage to get it sorted  :y
Post by: irratic on 30 December 2007, 17:05:37
steering box seems fine, it drives straight as a die, but its horific when you brake..but can't find anything loose or worn.. i'll try get it on a rolling road and see if that shows anything up.. thanks all for your suggestions
Post by: Marks DTM Calib on 30 December 2007, 17:07:36
Last time I saw such a problem it was due to a loose bolt on the wishbones so re-check them.......
Post by: Darth Loo-knee on 30 December 2007, 17:16:32
Yes it was asthough the car was skating all over the place... did it when going slow terrible, also when braking it would go left then right..
Check first like already been suggested mate..
From Greenhous in Hanley they want about £200 a side so think I will be having Patented once at £40 odd for a pair :y
Post by: irratic on 03 January 2008, 17:50:12
ok, i'm back for more ideas.. had the car up on ramps.. checked all the bolts, rechecked the brakes/calipers... checked for play in track rod ends , bottom ball joints and had a crow bar in the bushes on the wishbones.. checked for wear on the steering box... there is no wear /play or anything loose i can find, well me or 3 other mechanics (one of which is also mot tester)...its the strangest thing...
 question.. if it was an ABS valve block problem. would pulling the ABS fuse completely stop the valve block from working??? or if there were an internal mechanical fault within the abs block could it still cause uneven response??? although the car has also been on the rolling road and thats shown nothing up either... i'm grasping straws now...short of start replacing each suspension and brake part one at a time to try and find the problem.. any more ideas lads??
Post by: motmann on 03 January 2008, 20:23:26
what tyres are you running the omega on bud? are they directional and how many mm left on them?bit of a long shot but had this problem on a passatt a few yrs ago. did the problem come on gradually or almost straight away?
Post by: ffcgary1 on 03 January 2008, 21:58:50
Have you checked the front suspension legs for damage or lack of damping, worn shockers on the back and worn suspension bushes on the back can have an adverse effect on the cars abillity to steer straight and true.
Post by: andyc on 03 January 2008, 23:43:07
long shot but have you tried putting the car on the MOT brake rollers the checking each wheel and then both at the same time.
From watching the gauges each time it might tell you if the ABS is playing up and make the calipers come on and off
Cheers
Andy
Post by: irratic on 05 January 2008, 12:34:01
just an update... took the car for long abusive run...heavy braking etc.. and it now seems ok. whether it will last remains to be seen, in answer to the questions, yes the car has been to an mot station on the rollers, no problem with the brakes was found.. and we changed the tires incase it was them. but to no avail.. and now it seems to of corrected itself. which i'm not sure whether it is a good thing or not as we never actualy found what the problem was.... very confusing.... but thanks for all the help..
Post by: Markjay on 05 January 2008, 13:22:04
Right.... I seem to have the same problem... so there is still hope that it will fix itself.... thanks.
Could it be a problem with a certain area on the calliper cylinder or the clipper guides, and now that the pads have worn down a bit more, that particular problem area is no longer on the front line when braking?
Post by: irratic on 05 January 2008, 17:32:13
something tells me it may be something to do with the abs block.. what though i dont no..but if i find the problem i will certainly get back to you...
Post by: Dave-C on 05 January 2008, 19:05:37
Russ, have you tried a different pair of wheels on the front?  Mis-shaped tyre....
Happy to try to help if I can, just call / PM..
Dave C
Post by: markey mark on 05 January 2008, 21:18:40
have you tried pressure bleeding the whole system with new fluid bud ?? :-/
Post by: Kenster on 06 January 2008, 18:04:46
Hi guys, New Omega owner here.
I had this same problem.
I tried changing the calipers and the steering stabliser, with no luck.
I then thought I'd try changing the wishbones as I couldn't think of anything else.
When I removed the passenger side wishbone the rear bush fell off in my hand  :o
(http://i24.photobucket.com/albums/c31/ghostrider_kenshi/Wishbone.jpg)
Believe it or not the car was MOT'd like this less than 2 weeks ago.
To be fair to the garage that done it there didn't look like much movement in the bushes when it was on the car.......
So it could be worth removing your wishbones to see if there is anything hiding
Post by: ians on 06 January 2008, 18:43:20
..honest it did guv.. ;D ;D
Did that fix the braking problem?
Cheers and welcome!
Post by: Kenster on 06 January 2008, 20:19:43
lol,
Yeah its fine now.
Post by: JasonH on 06 January 2008, 21:10:49
My wishbone bush failed and caused a nasty vibration when braking but you couldn't see the problem until you took the wishbone off.
I tried levering it and even asked a garage for an opinion - they said probably warped discs - they were wrong.....
