Omega Help Area => Omega General Help => Topic started by: MikeDundee on 09 January 2008, 09:23:56
Title: C PILLAR TRIMS
Post by: MikeDundee on 09 January 2008, 09:23:56
Do the pillar trims just pull off?, as there are no visible retaining bits, gonna put in the rear blind parcel shelf today, so removal of the pillar trims will make it easier.
Title: Re: C PILLAR TRIMS
Post by: Andy B on 09 January 2008, 10:50:08
Yes they just pull off. When I removed my blind I had a swine of a job to do it, a bit of stray rear screen glue had also glued the rear shelf in too! :(
Post by: MikeDundee on 09 January 2008, 11:23:34
Just done it there are two torx screws with caps covering them, had to also remove the handle and seat belt, still can't get the bloody rear shelf out though >:(
Post by: Andy B on 09 January 2008, 11:32:53
Sorry. I was sure that the trim around the actual rear screen just pulled off, metal clips that act as a peg, slotting into a rectangle hole.  :-/
Rear shelf - rear head restraint recievers in the front edge to be removed & IIRC that's about all that holds the thing in.
Post by: MikeDundee on 09 January 2008, 11:42:03
Sorry. I was sure that the trim around the actual rear screen just pulled off, metal clips that act as a peg, slotting into a rectangle hole.  :-/Rear shelf - rear head restraint recievers in the front edge to be removed & IIRC that's about all that holds the thing in.
Yes there are those aswell :y, I released the 3 retaining clips in the boot holding in the back edge of the blind, still can't get the tinker out >:(
Post by: Andy B on 09 January 2008, 11:45:13
........ still can't get the tinker out >:(
You sure you don't have the same problem I had? It was only a little bit of glue but the shelf didn't let go untill I lost my rag with it!! :o  :o ;D  ;D
Post by: MikeDundee on 09 January 2008, 11:48:12
Could well be that, but I have put it back now, just had some lunch and gonna go back out and refix the pillar trim. As it appears the connections on the blind are not the same as the one in my boot >:(, have posted a thread in electrical on that ::)
Post by: Marks DTM Calib on 09 January 2008, 11:51:35
They are very slightly different.....on the facelift, the connector is 3 pin and includes a 0V connection....on the earlier ones they are two pin and the 0V is obtained from one of the mounting points............easy enough to sort.
Post by: MikeDundee on 09 January 2008, 13:19:33
OK then how do I sort it then get another connector for the blind or replace the one in the car?, can the bit be bought from Vx or try stealers?
The sun blind connector:
(http://i85.photobucket.com/albums/k65/mickdundee_01/2008_0109CPILLAR0004.jpg)
The connector in car:
(http://i85.photobucket.com/albums/k65/mickdundee_01/2008_0109CPILLAR0007.jpg)
Post by: markey mark on 09 January 2008, 13:25:29
cut both plugs off ands join wires mike !! should be same coulors  :-?
Post by: MikeDundee on 09 January 2008, 13:28:54
Was wondering about that, better nip up hellfrauds and get some connectors or crimps..........rear blind is a pain to get out, are they stuck with any glue?
Post by: markey mark on 09 January 2008, 13:33:08
not supposed to be bud ! but when i took that one out it gad been caught at the rear on window snot !! i had to remove rear screen to get it out for you !!  >:(
Post by: MikeDundee on 09 January 2008, 13:37:19
Well I appreciate that :y, I tried pulling and wangling it etc., still no joy, it's all back now, so will probably do it weekend now and take both C-Pillars out this time, I'll connect the wiring and test the blind works before I take all the bits out again and fit it :y
Post by: markey mark on 09 January 2008, 13:45:26
 no worries !! it defanitly works ok bud just need to connect the wires in the right order !! ;D
Post by: MikeDundee on 09 January 2008, 14:08:30
Any idea what the ampage is that runs through the wiring, got some connectors up to 8 & 10 amps.
Post by: markey mark on 09 January 2008, 14:56:06
no mate sorry not a lot wouldnt have thought !! i would use 10amp i think ! ;)
Post by: ffcgary1 on 09 January 2008, 16:28:31
Hi mike, i removed a blind for craig last year and the bugger refused to come out, it was being held by some rear screen bonding, which only gave way after some serious pulling, you can try pushing a metal scraper between the shelf and screen to realeas the hold. it will come out but pull hard. :y
Post by: Marks DTM Calib on 09 January 2008, 16:29:51
They should be fine.....if the motor was 120W then I would be surprised.
Post by: Kevin Wood on 09 January 2008, 17:26:33
.. and the blind would be shredded!
 ;D
Post by: markey mark on 09 January 2008, 17:30:01
you got it in yet mike ??  :D
Post by: MikeDundee on 09 January 2008, 18:39:59
Just come back from the pub :y, thats fine, I have 8 amp bullet connectors and 10 amp normal connectors, will rip it all out again tomorrow, try again >:(, hopefully get the job done, just don't want to break the shelf taking it out, and I know there are only three clips at the back, that I already pushed through ::)
Post by: Marks DTM Calib on 09 January 2008, 20:18:13
I suppose you want a list of what connector to connect where......
Post by: MikeDundee on 10 January 2008, 10:02:52
I think I know that one thanks :o..........gonna just use the 8 amp bullet connectors  ::)
