Omega Help Area => Omega General Help => Topic started by: omegaman2 on 11 January 2008, 11:22:56
Title: swapping oils
Post by: omegaman2 on 11 January 2008, 11:22:56
can you move from one type of oil to another without flushing ,
td oil to semi synth or full synth :question
Title: Re: swapping oils
Post by: Jay w on 11 January 2008, 11:53:19
I woulod say yes, but do the changes more frequently (3000k) in order to flush out the old stuff properly.
No point in going any higher spec that semi-synth
Post by: TheBoy on 11 January 2008, 19:09:42
I agree with JayW above, though a normal oil change for a TD should be around 3k, so initially change every 1k...
Post by: Markjay on 11 January 2008, 21:41:51
ALL modern engine oil are compatible with each other, so no harm will befall you if you mix them (though obviously for maximum protection you want to have as much of the higher-quality oil as possible...) .
So if you are running on say full-synth Mobil-1, and you discover that due to cam cover seals leak you are short of 1L, you will be better-off with topping-up using any semi-synth 10W-40 you can find rather than drive on until you manage to get some 'proper' Mobile-1....
