Chat Area => General Discussion Area => Topic started by: Jimbob on 05 October 2007, 19:51:53
Had some time, so got my hands dirty
Some of you know how new this is to me, trusted a mechanic friend until recently do keep our cars right, now trying to learn myself, all thanks to this place.
All on the 2.2, so nice and roomy...
Oil change ( I know, so what, but it was my 1st one !)
made a bit of a mess but I got there!
Coolant flush and header tank replace, old blue coolant gone, flushed with water, red coolant, then filled with red, looks nicer, and seems to run a few degrees cooler as well!
Tomorrow I'm going to do the Spark Plugs.
Like I say, this will sound like nothing to most of you, but is an achievement to me!
Well done. :y
It is a pleasure when you do the things yourself.. :y
Aye, real sense of acheivement
Right tool for the job helps too...
Started with the old halfords 150 piece jobby
After a mammoth job on my HBV earlier in the year, bought some laser hoseclip pliers from halfords, made the job a lot easier, highly recommended.
Bought a torque wrench as well today!
Need a better oil filter wrench though, my pound shop one just about did the job, but not very easily.
Well done Jimbob, job well done indeed :y
nice one Jimbob, makes you feel good :y
Well done, now have a go at the throttle body and breathers.
Throttle body and breathers were done earlier in the year, made a hell of a difference.
Would have tackled the job, but lack of a torque wrench has put me off a lot, now remedied :)
Ohh, did the air filter as well.
Sorry to say the car was that desperate for a service (been promising for about 2 months) that there is a noticable difference in the car!
Oil was very dirty, so I think 500 miles tops and I'll do that again.
Tunnies Oil & Coolant guides gave me the knowledge to try
down to AA's guide tomorrow for the plugs!
Well done Jimbob. :y
Good stuff, Jimbob. Even the longest of journeys have to start with the first few steps.... Well done :y
[size=10]'Kin 'Ell - thats a bit heavy for a Friday night and a few Bacardi's!![/size] ;D
Well done :y :y
Tho you've just reminded me I havent changed my plugs yet.....5k over due imo.
I usually change mine every 10k.....coz im on lpg.....it has been missing a bit more than usual lately :(
Oh and theres a brand new air filter sitting by the plugs that i havent changed either.....one in the car is the same as the plugs....done 15k :-[
Oh and a point.....recommended torque for the plugs is 25NM iirc.....which imo is bloody tight for them.....i was worried about snapping them or stripping the thread.....so i usually set mine to 20NM or slightly lower......but its upto you....too loose and they can vibrate loose....tho be interested to hear what others set their plugs to.....if you use a torque wrench ;D
Cracking job, glad it went well with no hitches :)
We all started somewhere, so an oil change and coolant change is an achievement :y
Nobody on this forum will laugh at you for having a go, and if something goes wrong, there is lots of help. Plus Mrs Jimbob has a permenent communication channel with the DTM household :y
Fair do's for doing that.....i wont do mine myself.......its a tad difficult where i live....plus i thinks its a messy job.....so i bung my local garage £20 for doing it for me.....so you've saved yourself at least £20....just for that job :y :y
25nm, with a v thin smear of grease on the thread...
I dont believe you James......you dont use a torque wrench ;D
Unless its mine, which i have back now ;)
Well done Jimbob :y If theres anything you need give me a shout :y
Cheers all, Spark plugs now done as well, car running beautifully :y
Excellent job....
What does Mrs Jimbob think to Mr Jimbob cutting his teeth on mechanics on her car.....
She is quite impressed!
Suprised she let me, after the axle stand incident at the lakes ::)
Torque wrench storage....
Should these ideally be kept a max / min / inbetween when not in use?
Turn them down to the minimum torque. This reduces the stress on the spring and stops them going out of calibration. :y
Yep, minimum.....although I suspect in reality it makes little difference...
Cheers, thats where I left it! good guess :)
I just use a hammer and screwdriver when it won't come off by hand, it's going in the bin anyway. I have one of those strap and socket type wrenches but it's more bother than it's worth to use.
a good bit of work well done :y :y
I tend to use those plier type filter tools - quick, easy, and ideal for V6 canister types, and diesel fuel filters....
And if you only tighten the filter up by hand from now on, you won't need a filter wrench / strap!
Good job Jimbob :y....................Is AA also giving you advice on how to clean the engine bay ::)
Keep up the good work Jimbob :y
