Omega Help Area => Omega General Help => Topic started by: 6cylinderman on 15 January 2008, 20:11:22
Title: Brown Goo / Mayo in Coolant Resevoir
Post by: 6cylinderman on 15 January 2008, 20:11:22
Hi fellas,
I've bought a 2002 Omega 3.2 with 50k.  It hasn't turned a wheel since November at least and only then it was started only briefly to come on/off a low loader.  I bought the car in the knowledge that it had suspected head gasket failure, but having done my research in the FAQ section first, this may not be the case.  My hope is that this has been misdiagnosed.  Anyway, here are the symptoms:
1)  There is oil contamination in the coolant expansion reservoir.  To be more specific, the reservoir is dyed brown and there are a few floaters in there along with "mayo" on the cap.
2)  The coolant isn't dyed i.e. its water and has been topped up with water as it's lost some coolant.
3)  There's some light smattering of mayo on the oil filler neck and cap, but absolutely none on the dip stick.
I'm hoping it's a combination of a failed oil cooler and heater bypass valve?  I'm no mechanic, so could the more knowledgable please help me out?  :-[
Title: Re: Brown Goo / Mayo in Coolant Resevoir
Post by: Timbuk on 15 January 2008, 20:16:13
Sounds like oil cooler
Post by: MutantCav on 15 January 2008, 20:18:17
Failed oil cooler for sure
Post by: Dazzler on 15 January 2008, 20:18:21
Does sound like the oil cooler. Don't think HBV problem unless you can see it leaking.....
Post by: shyboy on 15 January 2008, 20:23:43
You'll soon get very authorative opinions, but it sounds a classic oil cooler failure to me. Not necessarily a failed HBV as well, but if I'm right you're going to have to replace the oil cooler and flush the coolant system with special stuff to get rid of the gunge. A lenghty process I understand. Best to replace the HBV as well whilst you have better access to it.
A failed HG more commonly causes serious overheating and usually evidence of water in the sump, so if there is no mayo on the dipstick you may not have a failed HG. It's rare on the V6, apparently.
Stainless steel oil coolers are available which will obviously ensure a longer life.
Post by: Craig_R on 15 January 2008, 20:33:38
Dont forget if a car has mega mega over heated the oil in the sump will start to coagulate.
As I said in your other post I think its a oil cooler but the boys will be along to say 100%
Post by: Kevin Wood on 15 January 2008, 20:38:35
Souns like oil cooler.
Probably worth replacing the HBV, if there's any doubt, as well while you're at it, as it will be well gunged up (as will the rest of the cooling system). It'll need thorough flushing to remove this once done. I believe there's a Forte product specifically for flushing oil contaminated cooling systems. Have a look on ebay.
If it has been running with a weak coolant mix it could have been that which caused the oil cooler to fail so keep an eye out for evidence of leaks which would have prompted topping up (with water, by the sound of it >:().
Post by: Marks DTM Calib on 15 January 2008, 20:41:51
Its oil cooler.....but also remember this.....after stopping the engine the coolant stays pressurised long after the oil pressure has dropped away so you often still get some coolant in the oil.
Post by: Dazzler on 15 January 2008, 22:17:17
You will need to do several system flushes, so i would use Trafficfilm remover to start with to get most of the system clean. Then you can use Forte Cooling System Flush to finish off.
Post by: stuvaux on 15 January 2008, 23:30:50
My car has same problem. Had water leak for a while, now there is oil in header tank.....gonna sort it at the weekend...
Where is best place for new oil cooler, and are the stainless steel ones better?
Stu
Post by: davlad22 on 15 January 2008, 23:48:30
So, do you have to 'flush' the engine oil as well then? Forte?
Post by: 6cylinderman on 16 January 2008, 08:03:38
Thanks for the info, guys.  Phew!  Boy am I glad it' s the oil cooler and not the HG.   :)   I'll see to those other jobs while I'm at it.
I second the question: "Should the engine oil also be flushed?".  I don't suppose it would do any harm.
Thanks again.  I'll keep you all posted on my progress with "Project Plod".
Post by: Jay w on 16 January 2008, 08:47:42
Stu
Autovaux are a good place for oil coolers.
Whilst it may be a stainless one they supply remember that regular coolant/antifreeze changes will help to prolong the life of the cooler.
Flushing a system that has been contaminated can be a bit of a pain by all accounts
Post by: shyboy on 16 January 2008, 10:38:38
The consensus of opinion on here seems to be against flushing oil as it can theoretically move gunge to places where it can do more harm than if sitting in non-critical places.
My 2.0l had not had oil changed for a stupidly long time, so I went against the convention and used a flushing oil and then changed the new oil again after 2.5k miles. No apparent ill effects, but I suppose only time will tell. I honestly don't anticipate any problems. (Fingers etc. crossed).
If your engine has had water in the oil, or serious overheating, it may have caused gunge to invade the oil galleries etc. so flushing may be justifiable in this case. It could be the lesser of two evils.
Hopefully someone else will offer an opinion based on actual experience.
Good luck with the repairs.
Post by: Jay w on 16 January 2008, 13:48:26
drain the oil out, put a new filter on and then do a few more within a few thousand miles
Post by: Big_Roger on 16 January 2008, 18:05:28
Hi All,
I understood that VX fitted stainless steel oil coolers as standard from year 2000
Does any one know different ?
Roger
Post by: davlad22 on 18 January 2008, 13:47:59
6 Cylinder man's V6 hasn't done many miles so flushing the engine shouldn't really cause any ill effects?
How often is oil on police vehicles changed then? I'm guessing they're either really bad at this or really good!?!  ;D
Post by: Marks DTM Calib on 18 January 2008, 14:17:46
Hi All,
Roger
No, they were fitted from about 94/95.....
The part code we normaly advise on is the repair pack taken from the bulletin in TIS which includes a new cooler plate, cooler, nuts and O rings........this comes it at well under a ton unlike the individual parts that are well over 2 ton!
Add in the correct sealent (which comes in a small sealent type tube that requires a sealent gun), 4 douty washers for the coolant bridge, 4 metal washers for the oil pipes and your ready to go......you do need a 19mm crows foot spanner for the oil pipe to block joints.
