Omega Help Area => Omega General Help => Topic started by: PxMetro on 20 January 2008, 10:11:11
The Air Conditioning on my 2.6 seems to have stopped working. Can anyone tell what visible signs there are that the compressor is working ie: should the disc on the front be rotatong when engaged? If so how does this work? I have checked all of the fuses I can find, but all apear to be okay. I have also consulted my "Haynes" manual; and as usual the term "Chocolate Fire Guard" springs to mind. :-?
Cheers in advance
if the system needs regassing then i dont think the compresser will work,because the gas (in its liquid form) acts as the lubricant for the compresser. i would start by getting someone to check if it needs regassing and then go on from there if you need to.
Cheers in advance
If checked and all is ok then try this..............this was my problem along with a few others on the forum..
http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
Cheers in advance
The air con pully will rotate even if the compressor is not engaged. As said may need a re-gas. You can feel if the compressor is engaging through a change in vibration through the bodywork
Cheers in advance
Although the compressor on my 99 3.0 was engaged there was bugger all gas in the sysyem to do anything. I took it to an independant air con specialist last week for him to look at it. There was a whopping 200g(ish) in there, it should be nearer the kilo mark. Time will tell thoughhow long it stays put.
Not very good at working these forum things; but thanks all for the advice; at least I have a couple of things to go at.
Cheers
