		Omega Help Area => Omega General Help => Topic started by: megas on 21 January 2008, 18:04:04
 hi all,
 got hold of a exhaust manifold to replace my excisting one. quick question tho, as looking at the manifold at eye level the bolt on the far left has been welded in place and now is un usable, will this create a problem in the long run? i suspect it was snapped off and was a cheapo job.
 any ideas?
 liam
				Idealy you need to try and remove the broken stud and replace it, or you will probably find the new manifold will start to blow :(
				so you think it could be possible to make that hole good again? evne tho it has welding all over it?
