Omega Help Area => Omega General Help => Topic started by: popps258 on 26 January 2008, 16:56:23
Hi everyone, i still got to resolve my last post yet,
But need advice on fault codes? 3.0 ltr V6
After reading codes, Two fault codes are showing, A code 31 which means my crank sensor is naffed correct? and also code 73
air mass sensor low voltage/ Does that mean my mass air flow is also naffed? please advise.
many thanks
on a V6 code 31 is normal if the engine is not running, from memory code 19 is a bad one to have means the crank sensor is on its way out.
or it could be the other way around :) i dont have a V6 so i am just trying to remember, V6 guys will put me right
As its a v6, do paperclip test again with engine running.
The MAF error could be something other than MAF, for example, air leak, leaking EGR, etc
