Omega Help Area => Omega General Help => Topic started by: bob.dent on 28 January 2008, 12:53:08
Title: Rear seat jammed in estate
Post by: bob.dent on 28 January 2008, 12:53:08
I put the back seats down to move my mates bike yesterday, but when my mate went to put the seat up again he slammed it into place and trapped the seat belt and now the damn seat is jammed solid. The seat release button now has no "click" when you press it although it does spring back up, and the seat belt is jammed solid. Anyone got any idea's on how I can fix this?
I'm sure I can't be the only person this has ever happened to as it's so easy to do. :(
Title: Re: Rear seat jammed in estate
Post by: tunnie on 28 January 2008, 13:23:38
get in the boot ly down with head facing the exit, and kick?
Post by: bob.dent on 28 January 2008, 13:31:03
Yep, tried that and doesn't shift it at all. It's like the catch is released but the locking mechanism won't drop down due to the seat belt being trapped in it.
Post by: davlad22 on 28 January 2008, 13:32:27
Aye, brute force and ignorance! ::)
I wouldn't worry about damaging anything, it's all pretty tough, seatbelt, mechanism & seat etc.  :y
Post by: Marks DTM Calib on 28 January 2008, 14:32:21
Get somebody to push the seat towards the rear of the acr whilst pressing the button down......and hope that your mate in his infinite wisdom hasnt buggered the catch!
Post by: Elite Pete on 28 January 2008, 16:56:16
You will probably need a new belt as well :(
Post by: davlad22 on 28 January 2008, 17:08:41
Why?
Post by: Dazzler on 28 January 2008, 18:12:36
Why?
In case the latch has put a slight hole or damaged the belt, but it may well be ok, won't know of corse until its freed.
Post by: Elite Pete on 28 January 2008, 18:14:22
If theres the slightest hint of damage the belt will fail an MOT :(
Post by: davlad22 on 28 January 2008, 18:16:39
Really? Didn't know that. They are dead tough though. Would take some puncturing!
Post by: TheBoy on 28 January 2008, 18:18:22
just a crimp significantly weakens them, hence replacement if ANY signs of damage
Post by: davlad22 on 28 January 2008, 18:22:31
Better get it sussed then Bob!
Post by: Taxi_Driver on 28 January 2008, 20:37:13
Ive managed to do that Bob on my estate........rear seatbelt trapped.....but it hasnt jammed the seat before......unlucky  :(
Now im always careful when putting the seats back.....the seatbelt is clear.......tho unfortunatley that doesnt help you  :(
The only thing i can think of trying is with catch pressed down whack the back of the seat forward.....maybe a 2 person job   :-/
I had a pushbike in the back of mine today.......rear seats down job...........£5 extra charge  :y
Post by: bob.dent on 30 January 2008, 10:08:03
After much time and effort, still couldn't budge the damn thing so gave up and took it to my local garage as I needed a couple of other small things doing aswell. My mechanic had it free in about 10 seconds!!! :o
Only problem is, I must have bent the catch mechanism as it won't lock back into place unless you press the release button while pushing it back into place. :-[
Seat belt was fine - no damage at all. :y
Post by: davlad22 on 31 January 2008, 16:07:29
At least seat is up.
How's about a good squirt of the trusty WD!?! See if that frees things a little. The whole mechanism isn't great at the best of times. For confirmation whether you've bent it, check the other side I suppose.
Even on astras it's crap, sometimes the button doesn't pop up and you you have to 'coax' it by giving a few good bashes on the face of the seat.
Post by: bob.dent on 31 January 2008, 17:19:02
Can't see any visible sign of damage so will try a squirt of WD.
