Omega Help Area => Omega General Help => Topic started by: psl on 02 February 2008, 17:20:54
I have a problem with the autobox on my miggy and I thought I’d dip into the great pool of knowledge that is OOF.
I’ve not her long so don’t know how long this has been happening for but.
after a while I lose momentum I get High revs like its in neutral and the suddenly the box remembers what its doing and puts it back in gear with a thump, check automatic gearbox then comes up and its limp home time, however if I back off as it starts to rev high and change down a gear manually I can stop it coming up with a fault.
I haven’t yet checked the ATF level because I haven’t got a replacement washer for the level plug yet and its cold out.
I suspect it might be the selector switch, but am open to hear you views.
Pat
P.s Great Forum. :y
Sounds like classic thrust washer failure to me......bet if you drop the front sump off the box you will find the remnants of a washer.
If the LEDs by stick light up appropriately, then not selector switch.
First port of call would always be change ATF, but as suggested above, I suspect bits of thrust washer will be there.
Easy enough to replace thrust washer once box is off.
got to agree with Mark on this - similar thing happened to my box while on the way to the south of france a couple of years ago, wouldn't change down lots of clunks etc.
took the sump off to change the filter and found (what i now know to be) what was left of the thrust washer :o
ended getting a second hand box fitted for £500 :'(
guess from what the guys are saying you can sort the thrust washer prob??? :o
good luck :y
:( so what our my best options from here? reapir the box myself, get a garage to do it, or swap it out for another one.
And whats my time scale is it likely to wall apart at any moment or can I keep driving on it until it gets fixed?
thanks for the replys so far.
I wouldn't drive until fixed, unless you are going to change box anyway.
To change thrust washer, from memory, its:
Box off car
Remove TC and bellhousing (with oil pump)
Fit thrust washer
Refit
With the right equipment, probably around 3hrs?
