Omega Help Area => Omega General Help => Topic started by: VX1 on 04 February 2008, 19:27:49
Title: 3.0ltr Engine idle?
Post by: VX1 on 04 February 2008, 19:27:49
What is the actual idle speed for the 3.0ltr Auto?
Title: Re: 3.0ltr Engine idle?
Post by: Dazzler on 04 February 2008, 19:28:22
500-600 rpm
Post by: VX1 on 04 February 2008, 19:29:23
I would have thought it would be more than that? At least 750-800?
Post by: Darth Loo-knee on 04 February 2008, 19:29:37
Mine ticks over ay 500 rpm (without A/C on)
600rpm (with A/C on) :y
Post by: Dazzler on 04 February 2008, 19:30:35
Nope ;)
Post by: VX1 on 04 February 2008, 19:44:45
Well it looks like mine needs adjusting slightly then. It idles at a nats cock below 500 rpm and switch on the eco switch and it goes up to 500 rpm. Another quick question, Is the eco switch supposed to be on to lower the fuel econamy and to stop the air con?
Post by: Dazzler on 04 February 2008, 19:48:09
The ECO switch when on turns the air-con pump off, thus giving slightly better fuel economy.
Post by: Dazzler on 04 February 2008, 19:49:08
Has the car had a good service lately, including cleaning the breather system and the IACV?
Post by: hotel21 on 04 February 2008, 19:52:34
First check that the rev needle is at zero when the engine is off.  Could be the needle thats out of line, not the actual revs.
Can be checked with tech2, I believe....
Cleaning the idle valve with copious carb cleaner and shaking then giving it a slight lube with 3in1 oil (not WD40) will ensure the valse is doing its bit correctly.
Eco switch switches off the AC which removes the need for the AC compressor to be driven, hence system drops the revs accordingly.  Likewise when AC is on, aircon compressor is working and revs are raised to suit....
Post by: VX1 on 04 February 2008, 19:56:30
As far as I am aware No it hasn't but time permitting this will be done at the meet on the 23rd, (hopefully!!!!)  The unfortunate thing is I don't know the 3.0ltr so all this is new to me as this is the first time I have owned one. So if anyone is going to the meet on the 23rd then any help will be grateful  ;) ;)
Paul :y
Post by: hotel21 on 04 February 2008, 20:05:06
Paul :y
It is literally a 10 minute job....   :y
Post by: VX1 on 04 February 2008, 20:09:24
Paul :y
I suppose with guidence I should be fine then nudge nudge ;) ;).
Post by: hotel21 on 04 February 2008, 20:18:12
Paul :y
Post by: TheBoy on 04 February 2008, 21:24:34
450 on eco
600 with a/c on
